Question about Frigidaire FEF366DC Electric Kitchen Range
Exposed wires FEF366DC FRIGIDAIRE Stove/Oven Help! A critter came up through the hole behind my oven where the wires came into the kitchen and chewed through them. Now the wires are exposed. What can I do?
    President:
  • 2,992 Answers
If the critter chewed through the range cord insulation (from the outlet in the kitchen to the stove) you can get a replacement at most home centers or a well-stocked hardware store. The connections are made to screw terminals under a cover behind the stove. Take the old one along and match it to the new one. Be sure to tighten the screw terminals very securely when you put on the new one. (Obviously, you unplug the stove before doing any work.)
If the critter has chewed through the electric supply line to the stove outlet, call a licensed electrician to replace the damaged portion. You need to have the work done by properly licensed people to keep your insurance company happy, and often to stay legal with local codes as well.
Posted on Nov 20, 2008
Error code F-1 ...if we try to turn the oven on....the oven door locks. please help.
all solutions on the F1 show to replace the EOC control.(error board control)
Jun 09, 2011 | Frigidaire FEF366DC Electric Kitchen Range
Error message F!0 displayed
F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Sep 23, 2010 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire ceramic cooktop burner turned on by itself
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 28, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Dual element burner on glasstop range...inner element stays on
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Oven door does not close completel. Oven light remains on.
if it closes when you push against it, replace the door hinges
Dec 31, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire stove model gles388dsb
sounds as if there is a problem with the latch assy, there are 2 switches mounted on the latch mechanism for monitoring positon of hte switches, seems as if one has gone bad, not recognizing the door lock positon therfore continues to rotate without stop.part number for the motor latch assy w/switch and bracket 318095957 . located behind rear panel
Nov 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven error code keeps coming on
this could be as simple as needing a new oven temerature sensor, or you could need a new board, i would try replacing the sensor first....it is in the oven, towards the top, about4-6 inches long. you will probably have to take the back off to disconnect the wires...unplug the oven first
Aug 05, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire FEF366DC Electric Kitchen Range Logo
135 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
