MY PRINTER WILL NOT PRINT
NO CD TO REINSTALL PRINTER
  • 34 Answers
You can download the software online
Posted on Nov 20, 2008
Hp customer service
Normally this is the symbol that your printer is not on-line either for the reasons:
1) printer not turned on;
2) printer not connected properly;
3) printer driver damaged; - need to reinstall the printer driver with the CD provided;
4) print spooler service not activated in windows - need to enable the print spooler service in window console service;
Jul 25, 2014 | HP DeskJet 3940 InkJet Photo Printer
Pf3 shows red light instead of blue signal when ready to print. and so the cd do not stop to print but just freely passes through to tray.
Reset the printer , turn off, and disconnect the power cord or USB by 1 minutes and reconnect again. and try again.
However if the problem persist, unintall the software and reinstall again , and try again.
Otherwsie you mus contact to the supplier manufacturer via ONLINE chat for to get support.
GOD BLESS YOU
Nov 07, 2013 | MicroBoards Print Factory 3 PF3 CD/DVD...
Switching the printer on, it cannot print. the message was failed to print the document
-Restarting the computer and printer.
- Checked the USB cable.
-Check the printer spooler service is on( write "services.msc" on RUN, then check printer spooler is ready)
- Insert the printer cd and reinstall.
- after install restarting and print test page
Thanks and Regards
TRinoj
Aug 06, 2011 | HP Deskjet D2660 All-In-One InkJet Color...
Lexmark z2400 will not print, the comuter says document is pending. All connections are correct. Do I have to uninstall the printer, and reinstall with the CD? I rebooted the printer, and nothing. It is...
I am assuming you have it connected via USB to your computer. If you have an additional USB port on your computer then try powering off the printer, attach the USB connection to a new USB port, go to the Control Panel (Start, Settings Control Panel), go to Administrative Tools, go to Services, scroll down to Printer Spool, stop the service, start the service, and power on printer. Try to print a test page. If it fails, power off the printer and delete the print driver. Reinstall the driver using the CD.
Aug 30, 2010 | Lexmark Office Equipment & Supplies
When Verizon installed a new a new service I lost computer-printer communication. Do you have updated software to re install the print server again? Thank you for your help
you need to reinstall you print server
following is steps to reinstall print server
1. connect printer to print server with USB cable
2.print server to computer with CAT5 cable
3.put the CD (which you got along with print server) in computer
4.follow instruction step by step
5.It will asked you for IP address, you need to assign IP which is withen the range of your verizon modem(for example 192.168.0.50
after that it going to work
regards
prakash
Feb 12, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
My Epsom Stylus CX3900 series will not print
Normal 0 You have to reinstall the CD software program that came with the printer. During installation you will be asked what language and then select ENGLISH. Then follow the instructions.
But first do this.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 28, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
I have a HP Printer C5500 When I try printing something on the CD/DVD Directly I get a Error saying that the printer doesn't support printing directly on the CD while the Printer is meant to print on...
I'm confused.. Are you trying to print to a CD/DVD Drive? Try the print job again, and choose the C5500 as the print device.. Seems that there may be a problem with the print device set-up , and you may have to delete the printer, and reinstall it.
If the printer is designed to print a label on a CD / DVD. then you will have to use the programs provided to accomplish this, as it requires formatting parameters be sent along with the print request. I.E. You can not cut and paste directly to a CD / DVD printer..
Nov 19, 2008 | HP Office Equipment & Supplies
CAN NOT DELETE A PRINT JOB
Right click your default printer & click OPEN. Now right click on document , select delete/cancel documents.
If this does not solve your problem reinstall the printer, usually this will solve it.
Oct 26, 2008 | Office Equipment & Supplies
Epson Stylus R320 - cant align the CD tray to print....keeps showing error.
This printer has a bad system tray. If doesn't work in regular way, try inserting the cd tray from the back using the back slot and see what happen (usually works)
Oct 03, 2008 | Epson Stylus Photo R320 InkJet Printer
Printer will not print
uninstall the printer, reboot your system and reinstall the printer using your software/driver cd that came with the printer.
Nov 04, 2007 | Lexmark Z715 InkJet Printer
Computers & Internet Logo
32 people viewed this question
Alun Cox
David Payne
David Payne
