Question about NetGear RangeMax WPN824 Router
Wireless LED blinking, normal?
I have just installed a Netgear WPN824 Router and one day later, the wireless status LED is blinking like a blink per second. I am wondering if this is normal. I have not done any changes to wireless setup since the setup. Thanks.
  • 3 more comments
  • Huey Liu Dec 22, 2006
    Frst of all, thanks Sandrew. What worried me was that the wireless status light is blinking staedily even when no laptop is on. But I have compared it to a friend's router which is the same model and hers is also like this as well.
    So, I guess, as long as the uploads/downloads still works, the blinking light can be overlooked for now.
    But, thanks. I have checked the manual and it was vague on the blinking part.
  • me me Jan 14, 2008
    my wireless led is also blinking... which I am also wondering - esp. because I have got connections interuption regulary... What makes me also wonder is that the blue "dome lights" - 2 Leds consistant on and 5 running around in a circle. After my first setup they have just blinking around... strange ?! Any information about that ?!
    I have similary situation with the router. in the manual it only says WLAN LED on = wireless connection working - OFF = out of order. I have got connection interuptions - so I do not think its normal... I also have a strange thing about the blue dome lights - normally 7 leds should just flashingaround - my router 2 blue LEDS permanently on - 5 running ariund in a circle... strange any information about htis ?
  • ejmon86 Aug 24, 2008
    I have the exact same issues as discussed here. There are a ton of wireless networks around me, including some NetGear hardware. I've tried switching channels to no avail.
  • Anonymous Oct 04, 2008
    blue LED doesn't com
    Welcome Back:
    Visited the website for 2 consecutive days.
Same problem here - wireless light starts blinking and I get a network interruption. At that point, I have to walk across the house and downstairs to cycle the power on the router to get it working again. What a pain - and the manual doesn't even mention a blinking status for that light. I'm thinking about hooking the router up to a automated power switch (X12) so I can remotely cycle the power.
Posted on Jan 26, 2008
I'm having the same probs but, to answer your concern over the blue lights,her'es the deal.
your router has 7 antennas inside and each of the led's represents an antenna. as the router scans for something to connect to the led's will blink. it will eventually lock on to a signal from a wireless laptop or usb reciever and the 2 strongest signals will be used for transmitting/recieving data, shown by 2 solid led's.
Posted on Mar 13, 2008
I have the same problem with the wireless led indicator. After reading lots and lots of manuals and web pages, it seems that it may have been a fix for some kind of bug related to Wireless Router Radio. The led never used to flash, and I only noticed it flashing recently when I moved it, I also updated the firmware recently so I think it is probably supposed to flash now.
Posted on Apr 29, 2009
    President:
  • 2,961 Answers
You would have to check the manual about the flickering, but your wireless card may send a signal every second to keep connection to the router. Also the router may be trying to connect with another peice of hardware, make sure that you are at least WEP secured, so as there can be no unauthorised connection to your router.
Posted on Dec 21, 2006
SOURCE:
My Netgear WPN824 wireless router stopped working. With the exception of the internet LED (which doesn't come on at all), all of the lights are blue and doing sort of a slow, pulsating blink. No m
The RESET button is for resetting the wireless section of the router and does not effect the Internet connection.
It looks like the wireless access is faulty especially when you cannot reset and configure the wireless settings.
Try powering off the Netgear for 10 mins the connect the power again.
If you still cannot RESET the Netgear then it is faulty and you need a new wireless router.
Mar 07, 2013 | NetGear RangeMax WPN824 Wireless Router...
I have a router Netgear fwp114pv2 .. power led and test led blinks and the router stuck at this blinking
Try RESETTING the router.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jun 09, 2011 | NetGear FWG114P Router (FWG114PAU)
We are using WGR614 V8 Netgear Router it was working fine but one day after putting power switch on front panel of Router Power indicator LED and wireless LED are not glowing but Test LED, internet LED and...
no it never needs a hard ware repair... doing a hard reset for the router will help... press and hold the reset button on the router for 10 to secs using a paper clip or any safety pin.... reconfigure the router when reset is done completely...
Dec 13, 2010 | NetGear WGR614 Wireless Router
I had my Laptop worked and it was reset back to out of box
You need to RESET your wireless router. Her is how: Press and hold the Default Reset button until the test light blinks on (about 10 seconds). Release the Default Reset button and wait for the router to reboot. The default administrator's password is password The default IP is 192.168.1.1 Hope this helps
Jun 11, 2009 | NetGear RangeMax WPN824 Wireless Router...
My Netgear WPN824 v2 router won't work with my ps3?
hi, try setting a predefined setting
Ip adress : 192.168.1.200 ( or any number not used by pc )
Dns : 192.168.1.1
Gateway : same as DNS
Feb 28, 2009 | NetGear RangeMax WPN824 Wireless Router...
Works for short time then all lights blink
u ned to make sure router has been properly configured.u may give a try by logging into the router webinterface using 192.168.1.1/routerlogin.com
once u have opnd the router page clik on "basic settings-no and apply the settings",then clik on "router status" and check for ip address internet port(should not be o.o.o.o),if it has some numbers(perfect),then clik on "wireless settings" under "setup" and do all the wireless settings as per requirements
i hope u will try to do all these steps
Jan 10, 2009 | NetGear WGT624 Wireless Router
How to add a laptop to netgear wpn824 router
access the router page and you will see the wireless settings. if your wireless network is password protected then you may have to enter the password in order for the wireless router to connect.
Oct 05, 2008 | NetGear RangeMax WPN824 Wireless Router...
Weak connection with my xbox 360
The best way to make the wireless connection stable is to do some changes on the wireless settings of the router , like changing its wireless channel to the highest one to avoid any interference on your area.........
Sep 15, 2008 | NetGear RangeMax WPN824 Router
Netgear router
First I need to know the following infor to provide you some solution to your router problem;
Internet Service Provider:
Modem Brand Name:
Laptop Model Numbe:
Laptop OS:
Jul 30, 2008 | NetGear RangeMax WPN824 Wireless Router...
Reset
You can reset your Netgear router/wireless wpn824 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless wpn824 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear wpn824 router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the wpn824 router has been reset.
Feel free to get instant online Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Dec 15, 2007 | NetGear RangeMax WPN824 Router
NetGear RangeMax WPN824 Router Logo
6,641 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
