Question about Ricoh Aficio 220 Laser Printer
Lite character i was getting lite character, replaced the toner still the same thing, also toner are getting on the trays. need a second opinion. printer, ricoh aficio 220
  • 162 Answers
This copier must be very uncontrolled, if toner that you use are not original, the problem can be there, probably must change the image unit.
Posted on Sep 04, 2009
  • 204 Answers
THE MACHINE NEED TO BE CLEANED FROM INSIDE. SOME PARTS ARE DIRTY AND THEY DO NOT APPLY WITH THE NEEDED VOLTAGE BECAUSE OF THE DIRT.
THOSE ARE LIKE CHARGE CORONA ,LASER GLASS UNIT OR THE DRUM UNIT IS WASTED AND DO NOT ATTACH THE TONER ON GOOD.
SO IF YOU HAVE A TECHNICAL BACKGROUND YOU MAY TRY OPEN THE MACHINE AND CLEAN THE MACHINE WITH VACUM CLEANER AND CORONA CHARGE WITH ALCOHOL BUT BE CAREFUL TO NOT TOUCH THE DRUM OR SCRATCH HIM OR CLEAN WITH SOMETHING YOU CAN ONLY WIPE THE DRUM WITH SOFT PICE OF CLOTHE
Posted on Jul 17, 2009
My Ricoh MP 2500 is showing me loading TONER and have toner inside what can I do to stop this help me out.
There are couple of things that can be at fault here, but unfortunately you might be looking at worst case scenario. A very common problem with these machines are the toner pumps that go faulty. You could first try and clean out the pipes that run from the toner hopper to the toner pump as they could clog up. Secondly you can remove the knuckle with the sensor from the back of the machine behind the controller and clean it out as well. If the machine still doesn't load toner after this you should look at replacing the toner pump.
Jul 21, 2016 | Ricoh Office Equipment & Supplies
Ricoh aficio mp 1600 add toner problem ?
If its not adding toner there could be 4 possible causes, 1.make sure all the covers are closed, if they are not then the machine will not "run" to add toner. 2.Did you check to make sure there is enough toner in the toner bottle. 3. when the machine starts running/adding toner, can you feel a vibration or hear noise like gears grinding/slipping, if so, call a technician to replace drum/dev gears.4. when you open the toner tray/harper/hopper, at the bottom there is a flat silver sliding plate, when you slide it open, is there toner falling oout of that hole, if not, ask a technician to strip and clean the toner tray/ harper/ hopper.
May 01, 2014 | Ricoh Aficio Mp-1600 Copier
My machine aficio 2045e give error toner signal even though toner in bottle is more than50% i make every thing but still appear add toner
Inside the toner feed mechanism there is little plastic fins that tend to break off. You will probably have to replace the hopper unit (The unit that the toner tube sits in) or in that unit where the tube opening sites you can either replace the feed chuck or if your handy maybe repair the feed fins. The chuck part pops out with plastic tabs.
Sep 14, 2011 | RICOH RICOH AFICIO SP C820DNT2 40 PPM...
I have a ricoh aficio MPC2050 copier V2295900860 and it is saying that the waste toner bottle is full and needs to changed how do i do this and where is the waste toner bottle located.
Hello!
Your machine have 2 waste bottles.
The bottle 1 is placed in the front door. (See the picture). You can empty it or replace it.
(is less expencive to empty it)
The secund waste bottle is in the left. See this picture
Now, you just need to make sure what waste bottle is mentioned in the display.
Hope this helps
Sep 12, 2011 | Ricoh Aficio 450 Copier
Where is waste toner bottle in ricoh aficio mp c5000?
waste toner bottle is just beside paper tray 1. its the left side small cover. open the front cover and open the screw from top and open the cover in front and pull the bottle out. if its hard then email me on ronils_singh@yahoo.com.au. i am a Ricoh tech. i will help you out.
Sep 27, 2010 | Office Equipment & Supplies
Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
Ricoh copier imagio error used toner bottle is full
Change the used toner botle,desasembly the LCT tray,open the front cover and change the waste toner bottle.
Feb 09, 2010 | Ricoh Aficio 450 Copier
Ricoh cl4000dn toner bottle sensor
The toner bottle sensors don't go bad too often. Do you have an extra yellow toner bottle? Try replacing that first. Compare the tray where the yellow toner bottle sits to the other three colors, and make sure nothing where the toner bottle connects is broken or bent.
Jun 22, 2008 | Ricoh CL4000DN Laser Printer
Red toner leaking onto "spongy" rollers and down onto the paper trays
Hi, its sounds like a faulty magenta cartridge. Contact your supplier for a replacement
May 13, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 17, 2007 | Ricoh CL3000E Laser Printer
97 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
