Question about RCA D52W19 52" Rear Projection Television
Greenish tint to picture
The green color seems to be dominating all images. Sometime the picture looks okay, but its not just the input from the cable it also is on my dvd player. I have opened the tv and all lights are on red blue and green, and there are three bulbs in the bottom that are on as well. I have tried auto covergence but still is not working properly.
    Genius:
  • 1,030 Answers
There may be a green tube issue or there could be a screen voltage or screen control adjustment issue. There is a control block with six adjustment screw inside the front panel in front of tv. WARNING high voltage exsit in this set and adjusting these controls really should only be done by a tech,....So be careful
Posted on Nov 20, 2008
46 toshiba plasma has red tint in back ground
If you can see the red tint with every input source and also in the On-Screen Menu, then this indicates that the Green phosphor is burning off of the screen faster than the Red and Blue. This is typical of plasma screens. Even if you dont watch a lot of golf or football, green is the most dominent color and burns out of the phosphur pits(pixels) faster than the Red and Blue. Take away green, you are left with Reddish looking screen and Pink whites. This is not repairable.
If the Menu looks nice and white, check your source cables.
Good luck
Dec 30, 2009 | Toshiba Televison & Video
Tip
My TV picture has a greenish tint.
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal is often coded in separate colors signal, and a bad cable can cause a green picture when red or magenta (depending on type of signal) are out.
A faulty receiver or DVD player can also send a bad output. Try connecting different devices to TV.
If the cables and receiver are OK there are also internal faults that can cause the same effect.
The fault depends mainly on the model and type of the TV set.
On all TVs a faulty input/output can cause greenish picture.
On all digital TVs the signal is also elaborated on different color channels . Video circuits are often located on digital board.
A fault on digital video processing can cause a green picture.
If you have a rear projection CRT based technology, one of the three CRT may be faulty, or the power board supplying the CRT (red in your case) may have blown.
In that case you will get a greenish picture.
If instead you have a CRT TV, a greenish picture means that the red gun inside the cathode ray tube is not working. The CRT itself must be replaced.
Generally, when the problem is not the video cable , or the connected device, the TV must be inspected and repaired by a technician.
If you have a new digital TV, as an LCD, Plasma, or any non CRT based technology, the problem is usually caused by cables, input output, or connected devices.
Check the cables thoroughly, if that is not the problem, call manufacturer to find the nearest repair service location.
on Oct 23, 2009 | Vizio L32 32 in. LCD HDTV
Color is a problem. Screen picture has greenish
well it seems you have an issue with one of your video boards, it could be that the Analog Video Board (the one with the inputs and outputs) is partially damaged, but it can also be your Digital Video Board, which is the one that projects the image
Jul 22, 2009 | Panasonic Televison & Video
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
May 27, 2009 | Dell Computers & Internet
Display has a green tint to it tho it looks fine on the laptop.
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loose cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Jan 21, 2009 | InFocus LP70+ Multimedia Projector
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Red tint is gone
It sounds like the red cable on your component input is bad, one way to check this is press menu and see if the menu bars and letters are the right color. if they are then you may have a cable issue, if they are bad you may have a bad DG board in the unit. This will probably require a service technician. Hope this helps
Apr 03, 2008 | Panasonic TC-32LX20 32 in. HD-Ready LCD...
Greenish tint
First of all component inputs are analog as the only digital inputs are the DVI or HDMI inputs on a TV. You might have color adjutments in the menus somewhere that allow you to compensate for color weakness on one or more colors. If not you most likely have a bad digital board.
Apr 07, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Tinted image
If you are plugging in a monitor cable, it is most likely a cable issue. I would try another cable and make sure the cable is seated firmly into the projector. If that doesn't help, check the port on the projector for bent or missing pins because it seems that not all of the video information is reaching the unit.
Feb 02, 2007 | Sanyo PLC-XT16 Multimedia Projector
Picture has greenish tint that I can't adjust out
There is a crt drive problem and you can isolate it by unpluggin g the set, removing the green crt socket, in the middle of the three tubes is the green tube by the way, remove one of the other tubes and switching the crt sockets and turn it on. If the set is still greenish, then the green crt is bad and needs replacement, if another color is primart, then it is going to be the green crt drive circuit and is going to need to be serviced. Good Luck
Oct 07, 2006 | Mitsubishi VS-45607 45" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
107 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
