Question about Sony Playstation 3 (PS3) Console
Ps3 corrupt is there any way of fixing the ps3 when it says hard disk corrupted instead of buying a new hard disk
  • Rmaxbank2003 Nov 21, 2008
    My playstation keeps saying hard disk corrupted and at the bottom of the screen while it was trying to repair itself the bottom of the screen was slightly red.
  • 36 Answers
Really the only thing you can do without voiding the warrenty is to call sony and see what the can do. If its still under warrenty then they can just replace the whole system for you free of charge.
Sony Computer Entertainment America
M-SAT 6:00 a.m. - 8:00 p.m. PST
Sunday 7:00 a.m. � 6:30 p.m
800-345-7669 (800-345-SONY)
Posted on Nov 20, 2008
Sony Playstation 3 (PS3) Console My PS3 hard disk is corrupted, It say to restore i put restore and nothing had been restored Bid
Corrupted hard disk? Lets see....
You could attempt to boot up the PS3 in safe mode and restore the file system (should delete any corrupted data). Describing how to start up your PS3 in safe mode would just be confusing, so instead here's a link to the official page on the PS3 Safe Mode feature.
Follow the instructions, and then I'd say try options 3 (Restore File System). If that doesn't work, try 4 or 5 (Rebuild Database or Restore PS3 System).
If that fails, you could just replace the hard drive. The PS3 uses standard 2.5inch SATA laptop/notebook hard drives (5400 or 7200 RPM). They can be found online at any computer parts website; for example, Tigerdirect.
If somehow the new hard drive doesn't fix it, or you don't feel like buying a new hard drive, you could send the PS3 back to Sony. If you're under warranty it's free; otherwise it's expensive (150$ I believe).
If you request the repair service, they send you a box, you put the PS3 in it and ship it back to them. A month or 2 later they send you a fixed/different PS3. Simple, but takes forever to get a working PS3 back which is why I suggest you try a new hard drive first.
Anyways, hope you get it working soon!
Mar 22, 2011 | Sony Playstation 3 (PS3) Console
My screen says cannot start. The correct hard disk was not found. what do i do?
Id say you have a corrupted HDD..
This happens if you turn the ps3 off alot by the switch instead of going to shutdown.
New HDD should fix it
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
Hard disks file is corrupted
Has it asked you to reformat the hard disc? If you have tried that and it still doesn't work then you may need a new hard drive. Don't worry, for $20-$50 (US) you should be able to fix it. Without knowing what happened before that it's hard to say. But my best guess is that the hard drive is internally damaged in some way. Just take off the small panel on the left side, remove the screw, use the little handle and gently pull to the right then out. It should be a Seagate SATA hard drive 20, 40, 60, or 80GB. Just buy a new one from your local store or online. Make sure that you mark the bad one before you get the new one near it so you don't get tem mixed up. Then remove the 4 little screws on the mountinng cage, switch hard drives, install back into PS3 and it will give you the format screen again. Click yes and it will format, turn off, back on, and you should be all set!!
May 04, 2010 | Sony Playstation 3 (PS3) Console
Hard disk files are corrupt
you need to take out you hdd and format the disk or do like i did and buy a new hard disk. then put it back in .
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
Hard disk corrupted
vlynch2819
If you are getting the corrupted drive message on your Playstation 3 this means you have corrupted data on your hard drive. The link below will help you fix the problem with the corrupted data. Note if you still have trouble then you will need to replace the hard drive as there is something wrong with it.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or question
Issken
http://www.fixya.com/users/issken
Nov 01, 2009 | Sony Playstation 3 (PS3) Console
The hard disk file system is corrupted
When the hard disk is corrupted you can either send the PS to sony or buy a new 2.5 sata hdd, and reinstall the system.
First you can try formatting the HDD.
Contact Sony for further instructions.
When HDD is corrupted data are generally lost.
Regards.
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
Question about the hard disk
Your hard drive has been corrupted. There is an easy fix that will not void any waranties (If you have them). Just buy a new hard drive (Mine is a 500 GB Samsung for $125). Then lookup instructions on how to replace it on the Sony website. It is a very simple process.
Hope this solved the problem,
Mike P
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
Hard Disc Corrupt .
no sorry you need to buy a new one
Jan 31, 2009 | Sony Playstation 3 (PS3) Console
PS3 corrupted hard disk
Yes. All you need is a Seagate SATA 2.5" hard drive. It doesn't matter how many GB it has. If you have the 20GB or 60GB model of PS3 for goodness sake keep it!! That model is backwards compatible and will play PS1 and PS2 games. The 40GB unit does not have this luxury. I hope this helps you. Good luck and happy gaming!!
Aug 28, 2008 | Sony Playstation 3 (PS3) Console
Sony ps3
just buy a new hard disk i got mine from a store called frys. Walmart will work also or any computer store. I now have 160 gig hard disk in my ps3 Yea!!!
May 16, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
50 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
