Question about Apple iPhone Smartphone
My iPhone won't show my recent/recieved calls or my missed calls
I have a 2.0.1 jailbroken and unlocked iPhone. Recently when I went to check my phone calls I realized they had all been erased. Thinking that maybe this was an error on my own part I did not think much of it. Later when I went to use the jailbroken application called iLog, which is a call editor and text editor program, I saw that it was not working. Attribuing this to what was causing the problem I tried reinstalling the app. Still not working. I tried deleting the app completely thinking maybe this would fix the bug. Yet that did not solve the problem either. What can I do other than resetting the phone.
  • kwalkup Dec 03, 2008
    same problem here, 2.2 jailbroken iphone and everything works except the phone icon , when i go to type a number it just goes back to the home screen?
MakikiChris
  • 84 Answers
SOURCE: Could Not Save Call Waiting Setting
Hi Chad....I believe that applying the iPhone Update and Patch v1.0.1 will heal your phone. Begin by connecting your iPhone to iTunes, which is your only method of retrieval for this patch, and click on the Check for Update Button on the Summary Screen, and when prompted, select Download and Install. Be prepared for the possibility of what may feel like a lifetime to compelete. This Update is Proactive, meaning, it will continue to patch, and heal your phone, until every single flaw and or slight corruption is healed, even if it must update your phone to straight-from-the-factory default condition. (don't you just love that new phone smell?) Please update your post whether your results are positive or negative so that other contributors including myself are aware of your status and/or developments.....good luck my friend
Posted on Aug 03, 2007
SOURCE: My iphone doesn't turn on
Try doing a factory restore using iTunes or QuickPWN and if you need to jailbreak it again, be careful what apps you download from cydia...some of them cause problems with jailbroken iPhones, just research online for which ones are notorious for problems
Posted on Jan 05, 2009
SOURCE: 2.2 Jailbroken iPhone 3G dailer crashes! Help!
If after the jailbreak you can't make dial calls because the phone dialer freezes and goes back to the main menu, try this:
1- Uninstall Kate from Installer: this is what everyone recommends, seems to work for a lot of people but didn't work for me.
2- Then go to Installer again and uninstall these apps:
A) Mobile enhancer
B) RIP DEV preferences
3- Reboot your iPhone.
That's what I did and got my dial pad back again.
Posted on Jan 08, 2009
SOURCE: How to recover Restriction Passcode - iPhone 3g 2.2.1 jailbroken
ok! I figured it out... What I did was, I simply restored the phone with the backup taken from another phone with the same name and now my Restriction Code is blank (as it was blank in the other phone)
Posted on Jun 22, 2009
Joed911
  • 4338 Answers
SOURCE: frozen jailbroken iphone 3g
Try to reset the phone:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Posted on Jul 24, 2009
My iphone will not ring and i checked the orange dot
Some users who have recently updated/restored to the new iPhone firmware 3.0 have reported to have got into a problem where their phone randomly doesn’t ring when there is a call nor does the keyboard or slide to unlock button sound anymore. I got into this problem as well after unlocking and jailbreaking my iPhone 3G with firmware 3.0, my iPhone suddenly stopped ringing on calls randomly, resulting in missing a lot of important calls.
So if your iPhone isn’t ringing sound on calls, or if you are unable to hear the keyboard or slide to unlock click sounds, then try the following fixes before you panic and call Apple support:
Fix #1: Push feature is currently not working properly on jailbroken iPhone’s. If you have installed an application which supports Push Notification System then try disabling the Push feature as it may solve the problem.
Fix #2: Try Resetting the iPhone: Settings > General > Reset > Reset All Settings. This will reset your phone’s setting to factory defaults. Your contacts, calendars photos and any other data will stay intact.
Fix #3: There is a slight possibility that your iPhone’s headphone jack may have got some dust or rust which is causing the phone to think that the headphones are still plugged in when they actually aren’t. Try blowing out air in the headphone jack or try plugging the headphones in and out repeatedly. This trick may solve the no sound problem.
Fix #4: Restore/Update you iPhone back and start afresh: If the above solutions doesn’t help in solving your problem then you will have to start from scratch by first restoring your iPhone to the the original firmware
3.0 from iTunes, jailbreak it using redsn0w and then finally unlock(3G users only) it using ultrasn0w. This has fixed my problem.
Fix #5: Install Insomnia from Cydia: Install Insomnia as your last resort. When you press the power button on the top, iPhone goes into sleep mode after 30 seconds, in the process turning off your WiFi, sound and other stuff. When Insomnia app (available for free from Cydia) is enabled, applications will keep running and sound & WiFi will stay connected when the screen is off. This should fix your problem if all of the above solutions have failed to fix it.
Dec 30, 2009 | Apple iPhone Smartphone
Iphone update by itunes to os3.1 can i reverse this.
You can downgrade the OS on your phone back to 3.0. You can use iTunes to restore the OS. If you don't have a copy of OS 3.0 , google for a download site. Once this is done, there are options to unlock the phone.
or check out
http://www.quickpwn.com/2009/09/jailbreak-iphone-3-1.html
Oct 01, 2009 | Apple iPhone Smartphone
Iphone 3GS jailbroken and unlocked 3.0.1 - emergency call mode
Apple's recommendation worked for me... Unplug the USB cable. Turn the phone off. Then hold the Home button while reconnecting the USB cable.
follow the link below,
http://support.apple.com/kb/HT1808?viewlocale=en_US
Alternate option is,
just have him keep trying to put it into DFU mode over and over again, sould work with in 1-10 tries. if you get stuck on something like this, i suggest he just keep trying to do the same thing, change things around, unplug things and then plug em back in.
good luck on not being stuck. stay with 1.1.2!
Aug 13, 2009 | Apple iPhone 3G Black Smartphone
Iphone 3g stuck in emergency calls only
Are you using at&t. if not it was jailbroken and unlocked and that went away after you updated it.
Aug 11, 2009 | Apple iPhone 3G Black Smartphone
Iphone doesn't ring out on sleep mode
Download the Insomnia app through CYDIA. Phone must be jailbroken to install this.
Aug 06, 2009 | Apple iPhone Smartphone
My Iphone 3G blutooth doesntwork and have internet problems.
the iPhone doesnt actually have the ability to send and recieve files from other phones. Its just for the headset ability. If your phone is Jailbroken you may find some programs out there that allows you to send and recieve messages and find other phones via Bluetooth. YES going on the internet without a DATA PLAN will cost you money. It depends on what carrier you are with, it will very on how much per kilobyte. You can not record videos unless you phone is jailbroken. Then you can download the ability to use the camera as a video recorder. Some of the programs are the following: Cycorder and 3G video recorder. Hope this helps!
Jun 06, 2009 | Apple iPhone 3G
Phone unlock
check out
www.quickpwn.com
Once phone is jailbroken download an app called yellow snow. This will unlock the phone. read up on site on how to do. Very quick and easy
May 28, 2009 | Apple iPhone 3G
Unlocked iphone
hey people i just got the new apple iphone only had it for 2 day's and i went to set a passcode and now it wont let me get call's or change passcode and it only let's me call 911 for a call out i really need help
thx desiree medina
Mar 20, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
1,006 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
