Question about Whirlpool LSQ8000LQ Top Load Washer
Machine fills up then empties out
When my older whirpool washing machine fills up with water and reches its proper level, it begins to go out as if it is finished. When it gets low enough it will start to fill again.
    President:
  • 878 Answers
Lett, check your drain hose and make sure there is a gap in the drain inlet. Sounds like you are siphoning. The question is whether the timer is advancing or the pump is running during this draining. If so, you have a timer issue. If not, it's probably a siphoning problem. Catriver..post back.
Posted on Dec 18, 2006
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
We have a whirlpool LSR7233EZO. When I set the dial where it should fill with water no water runs in but the agitator runs. This happens on any of the load choices. From what I've been able to find out I...
Your problem sounds like a faulty water level switch,not your fill valve. With the machine empty at the beginning of your cycles, the switch should internally be in the "empty" position to energize your fill valve solenoid(s), then when the machine completes the filling to the level selected on your water level knob, the level switch repositions to the "full" position to energize your timer to advance the cycle. If the switch is stuck in the "full" position all the time, as soon as you pull your timer knob out to start any cycle, the machine already thinks it has filled to the desired level, and immediately energizes your timer to advance to the wash step and begin agitation, even though the tub is dry. I will refer you to the following link for a video showing you the fill/switch replacement procedure: http://www.youtube.com/watch?v=bIs9gX0YjxI&feature=related
I hope I've addressed your problem as described
kcomp1863
Jan 20, 2011 | Whirlpool Washing Machines
Was wondering if the washer is supposed to fill to certain level at wash cycle?
Yes. On top loading machines, it is very easy to see. On front loading machines, not so easy to tell. Front load machines fill to a very low level, (which is why you should only use 1 to 2 tablespoons of HE soap with them) then when they begin to tumble (wash motion) the clothes absorb water, causing the water level to drop, resulting in the fill of additional water until the original water level is acheived again. This process generally takes several times to get all the clothes saturated and the water level to stabilize. Additionally, water valves may cycle on and off several times as the machine adjusts the water temperature, even if you were running an empty washer through a cycle. Gentle cycles will use more water, as more water = less abrasive scrubbing action. Normally, using front loading machines, you will not see much if any water through the door window.
Jan 02, 2011 | Washing Machines
Ariston A1436 The machine begins to fill then empties and fails
Make sure that the top of the waste water pipe is at the correct height for the machine, typically around 30-34 inches from the floor (see your installation instructions). If it is any lower then it will start a siphoning action as soon as the water reaches the same level in the machine and never actually fill up and hence the cycle will not start. If the machine detects that insufficient water has entered the machine within a given time, typically 8 minutes, then if flags an error to the on board controller. If the error persists after the waste pipe height is corrected then check out the pressure switch for correct operation as if this is not triggered then the cycle will also not start or will halt almost immediately.
Oct 25, 2009 | Washing Machines
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Filling With Water
"preesure switch" built into controller, remove 2 screws behind console nad check the clear hose hasnt become diconnected, or perhaps has a crack in it not able to "read" water level
Mar 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Imperial
With the machine off and empty, fill the softner bin with water only. Does the water level go down or stay the same.
Nov 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSQ8000LQ Top Load Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal De
