I have a 55-in mitsubishi projection TV. Occassionally, a double image appears of all letters, etc. I go into the advanced feature mode into convergence mode to reset and it seems to work, but then it happens again. Any help would be greatly appreciated
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
