Question about Konica Minolta PagePro 1350W Laser Printer
Konica minolta 9J04 refill
I have konica minolta 9J04 black cartridge - I would want to know the refill instructions, the process seems to be very simple - cap removal, refill and cap replacement - though my friend using the same printer with the same cartridge claims it cannot be refilled - as the chip needs to be replaced!
is it true?
can the chip be reset? is there any way i can reset it my self without the use of any special device??
plz help
  • clauson95 Nov 26, 2008
    I HAVE BEEN SUPLIED NEW CHIPS WITH REFILL PRODUCT 2 REFILL $10 W/2 CHIPS
    BARNEY
  • 210 Answers
Unfortunately you have to replace the chip or to reset it after the toner refill. The chip keeps count of the number of pages that was printed with that toner, so there is no easy way out.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Posted on Aug 23, 2009
  • Konica Minolta Error Codes and Solutions
    Chip
    Chip
SOURCE: lexmark z1300 ink jet cartridge refill instructions
In order to refill the black ink cartridge on a Lexmark 1300 you need to purchase a 28a (18c1528)
cartridge. The 28 black ink cartridge is a return program cartridge and it won't let you refill it.
I found one at a site called computer friends for around $21.00. You can also google lexmark 28a ink
cartridge you can find them. I hope this helps. I've been frustrated with this problem also
Posted on Oct 15, 2008
SOURCE: refill clp-315
No need to drill holes. If you turn the cartridge with the drum facing away from you, on the left hand side, you should see a small block elliptical cover with a couple of divider on it. That is the cover for filling the cartridge. The problem is there is no available reset chip yet for clp-315.
Posted on Mar 08, 2009
Idaho_Biker
  • 32 Answers
SOURCE: ''low ink'' message with newly refilled tank
Well I did some Research and came up with this "Link" that MAY Help You (Both) about this issue, this is by no means "My Expertise" area, Just decided to go out and "Look" around....seems like a Great Place to start.
http://forums.afterdawn.com/thread_view.cfm/682547
Posted on Apr 10, 2009
SOURCE: Minolta 2530DL cartride reset problem
Take the cartridge to Cartridge World they will fix the issue they have fixed it for me in the past. They really know what they are doing just bring the cartridge to them and they will help you
Posted on Jun 10, 2009
komguy
  • 2306 Answers
SOURCE: Canon MP610 ink refill
Without the resetter it will continue to give error codes, holding the resume button for 5-10 seconds sometimes will turn off ink level reporting, but you either need the resetter or to purchase and install reset circuit boards on each cartridge you refill.
Posted on Jun 19, 2009
Konica Minolta pagepro 1580 error showing refill cartridge...
replace the cartridge with a OEM cartridge DO NOT refill they have sensors on them once the sensor knows its gone refilling will not help
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 30, 2017 | Konica Minolta Office Equipment & Supplies
How do i refil konica minolta pagepro 1500w
Buy OEM CARTRIDGES. The cart ridge have sensor on the machine can tell used from new
Dec 07, 2014 | Konica Minolta Office Equipment & Supplies
Filling ink
The cartridge have chips if they are not replaced then the copier /printer still thinks the cartridges are old
Apr 05, 2014 | Konica Minolta Office Equipment & Supplies
Toner error
There are chips on the toner cartridge, that how the printer known it got a new cartridge so refilling does not work.
Jan 05, 2014 | Konica Minolta PagePro Office Equipment &...
How to refil konica minolta toner
Shop for the appropriate refill kit. When purchasing a refill kit, double-check to be sure that the toner in the kit is compatible with the toner required for your model of Konica Minolta printer.
  • Step 2 Empty the old printer cartridge. Be sure to completely empty the printer cartridge that you plan to refill. A compressed air can is ideal for this purpose and can be purchased online or at most office supply stores.
  • Step 3 Remove the plug. The cartridge plug may be covered by a colored end plate, depending upon the model of your Konica Minolta printer. Simply unscrew the end plate, and then remove the plug. If using a screwdriver to remove the plug, be careful not to puncture the plug, as this will cause the toner to leak out of the cartridge and into your printer.
  • Step 4 Refill the printer cartridge. Shaking the powder in the refill toner bottle before attempting to pour it into the cartridge will cause it to pour much more easily. Do not squeeze the bottle, but allow the toner to simply pour out. Replug the cartridge, and gently shake or rock it back and forth two or three times to evenly distribute the toner powder inside the cartridge.
  • Step 5 Check for leaks. Before returning the cartridge to the printer, check the outside of the cartridge for any powder particles that may have spilled or leaked during the refill process. Wipe the particles off the cartridge, and gently shake it once more to check again for leaks. If no powder particles appear, then it should be safe to return the cartridge to the printer.
  • Step 6 Return the cartridge to the printer. Once you have refilled the printer cartridge and have checked for leaks, you may now return it to the printer. Go to your printer properties/settings and select the option to indicate that a new printer cartridge has been installed. Print a sample page to check print quality
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    May 22, 2010 | Konica Minolta PagePro 1350W Laser Printer
    Minolta 2430dl, cyan, magenta, and yellow toner cartridges all show empty. Black shows 42% remaining. How do I get printer to print?
    Some printers will refuse to print _anything_, until you replace/refill _all_ of the empty toner cartridges. So, replace/refill.
    Dec 30, 2009 | Konica Minolta Office Equipment & Supplies
    My Minolta Magicolor 2500W printer indicates that it is out of black toner. I have never changed the toner cartridge before and cannot find the instruction manual. (bought it almost 3 years ago...) Do I...
    Firstly buy a black toner refill and a "CHIP". The chip is a small printed circuit carrying a chip, mounted on the top right hand corner of the toner cartridge held in by a small cross point screw. Remove the cartridge and looking at the right end you will see a round (About 3/4 inch dia) plastic bung. Lift this bung out and carefully refill the cartridge (The refill supplier will probably clarify this I am saying). Replace the bung, clean up all the messy dust and remove the old chip replacing it with the new one. Make sure you dont lose the little screw and insert it fully without over turning it. Thereafter all should be OK.
    Dec 05, 2009 | Konica Minolta magicolor 2500W Laser...
    Konica magicolor 2400W
    To clear chip after refilling toner cartriage.
    Go to "Tonerfillyourself.com" I bought refill toner and it includes a new chip and it's not hard to replace it. (Comes with instructions)
    Apr 09, 2008 | Konica Minolta magicolor 2400 Laser...
    Konica Minolta PagePro 1350W Laser Printer Logo
    578 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Adorjani Laszlo
    carpediemweb
    Level 1 Expert
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
