Panasonic DVCPRO SD255 deck wont eject tape and display E-31 error
Is there a solution for this?
Posted on Nov 26, 2008
My Panasonic AJD230 is spitting out some but not all, tapes
The capacitors are old and need replacing. And what I mean by caps is ALL the caps. These decks are known for failing capacitors - even if the deck hasn't logged much play/record time - time is not kind to them. Panasonic have ready made capacitor sets for the decks and even though you might be able to fix your transport problems by replacing only a portion of them, it's advised they all get done at once. That's between 10-20 hours for an experienced tech and it will cost you. What can you do?
Oct 26, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
I am trying to use a Panasonic AJ-D650, which hasn't been used for about 5 years. Initially the DVCpro tapes wouldn't load but they are now loading correctly. However if I press play or any other command...
most likely problem with the AJ-D650 is deteriorated electrolytic capacitors on the mechanism drive board. when these caps fail, the mechanism will not load completely, if at all. also check for bad capacitors in the signal path from the head drum. first and easiest step is to clean the heads; often a good cleaning will restore operation to a non-playing machine.
Oct 22, 2009 | Panasonic Televison & Video
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Error Code C:31:00 in a Sony CCD-TRV75 Handycam Camcorder
    This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment
 Thanks for using fixya.
May 21, 2009 | Sony Handycam CCD-TRV75 Camcorder
Tape deck no longer plays large DVCpro tapes
the tape compartment elevator has switch senors that tell the machine what size tape is in..
does the tape load all the way.. you need to tell us
is there an error code ?
either the sensor or the reel motors the feed and uptake the tape,,
they ride on rails and slide into position to accomodate the tape side they could be having trouble moving, dirty, broken actuator
Apr 07, 2009 | Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
DVC recorder
The physical tapes are the same size, but the encoding on the tapes are different. Unless the panasonic recorder can play DVcam, you're out of luck.
Dan
May 08, 2008 | Panasonic AG-DVC200 DV Digital Camcorder
Error "04" on display & tape won't eject
you have bad capacitors in your power supply. i would suggest you take your unit to a good shop in your area and request a power supply re-build and mode switch cleaning.
Jan 22, 2007 | JVC BR-S822DXU VHS/S-VHS playback VCR
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
Electro Med Services...
