Question about Samsung SRS20DTD Side by Side Refrigerator
Control panel inactive
Moved my frige a short distance and now the led lights are not working, they are both showing 88 degrees, interior lights come on when doors are open but control panel remains inactive, motors are not running. when moving frige it was at an angle but not flat?
  • michael hyder Dec 20, 2006
    Could the ambient room temperature have any affect in its operation if moved to a colder room/
  • flash263 Oct 10, 2008
    I have the same problem the control panel just stopped working, but I did not move the refrigerator. We opened the door and the front panel lit up and was beeping and just stopped displaying and it no longer beeps when the door is open to long.
  • 237 Answers
See if you accidentally unpluged or damaged any wires under the refer during the move. There are connectors that can sometimes easily pull apart if a dolly hits them.
Posted on Dec 20, 2006
I have a 2008 ford f150. I was changing my interior light - short.my insturments stopped working-instrument panel, All windows stopped working,my interior lights don't work. I Checked several fuses
I was changing my interior light ? which light ? What's with - short ? You short the wire for the interior light ? Need more info ? The interior lights on your vehicle are controlled by SJB - smart junction box . All the thing's you have listed are controlled by the smart junction box ,fords BCM - body control module .
Jan 20, 2017 | Ford Cars & Trucks
Which fuse is for the instrument panel back lighting?
Does the radio play ? Are any other back lighting components not lighting ? Does the HVAC control panel light up ? You probably need new radio !
The second interior lighting group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination, LED illumination and incandescent lamps.
When the ignition switch is turned to the RUN position, the radio VF display turns ON at maximum brightness. When the park lamps are ON, all incandescent and LED back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. The panel dimmer switch potentiometer is an input to the body control module (BCM). When the driver selects a dimming setting by moving the I/P dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Dose
Jul 14, 2015 | 2008 GMC Sierra 1500
Bajaj Pulsar 150cc Dtsi right side indicator working but showing inactive in the meter guage panel, left side indicator is not working but showing active in the meter guage panel. pls sugges me what to...
Hi, I would check the bulb[s] on the side that doesn't work. You may find the relay that switches the indicators needs all bulbs to be good to operate correctly. If you get all the indicators to work and the meter panel still shows inactive (I assume you mean the warning light does not work) then check the light in the meter panel.
Jan 29, 2014 | Bajaj Pulsar 150 Motorcycles
Hi just wondering if there is a way to turn off the orange indicator light on my dell laptop that shows the touchpad is inactive. The light is really annoying (I want the touchpad to be inactive but not...
This is an incredibly simplistic fix but it might work for you purposes. I don't know of any way to
turn this light off but you might be able to cover it with just a little electrical tape.
May 06, 2011 | Dell Inspiron M5030 Laptop
This is the 3rd time I have had this problem, my Neptune sensor touch pad dryer will not start, it reads 8.8 on the display. If I unplug the unit so that only one side has power (110), when you open the...
We have the same Maytag Dryer MDE5500AYW and after reading a few posts of possible fixes--Turn Power Off them back On to reset---Replace Control Board-- Then I saw APPLY HEAT to the panel control area AND IT WORKS. I put a small heater on the dryer top in front of the Control Board Panel Readout and after it warmed up the 88 went out and when I pushed Start It Works.
I think that cold weather has something to do with the problem. In Dallas it is 42 degrees outside and 70 degrees inside But the dryer vent is connected through the outside insulated brick wall and the cold air coming forom the outside vent makes the inside of the dryer COLD until the dryer is in operation.
Long story short--I will keep the heater handy in case It is needed until the weather warms up.
Roger
Dec 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Refrigerator interior heating upwards of 90 degrees/freezer seems fine
is you freezer freezing if yes is your evaporator motor in the frezeer running.
if yes then it might be you damper assy that is not opening but on GE'S most of the times that run call with that problem the evap motor is not running does your frige have a computer at the back if you do then you have to trouble soot that computer or call a tech or just repl that board and if it doesn't work just return it
Oct 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Your refrigerator is in demo mode. Review your manual on how to remove it.
Feb 24, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
387 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
