Question about SanDisk Sansa e250 MP3 Player
Problems with using micro sd on sansa e250?
Whenever i put it in, it freezes. even when it is on and when i put it in before i turn it on. is there a special micro sd card for it or my own is ok?
  • 758 Answers
It sounds like there is a problem with the sd card you are using...There isnt a special sd card you can buy..what you can either do is to format the sd card and buy onother...you can buy them directly from this website....
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=380&SRCCODE=WEBGOOFLASH&cm_mmc_o=7BBTkwCjC-p8ByplCjCabTwyKbywgfCjCmH4
I hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on Nov 21, 2008
My sansa player does not recognize a micro sd when its inserted
Sorry, it doesn't work that way. You can use a separate card reader to put files onto the microSD card. When the card is installed into the Sansa, the Sansa will see the additional music.
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
How do i use a micro sd card with my sansa e250
It's pretty simple really. To actually get music on your micro sd card you have to put it into an adapter and connect it to your computer. Then you have to put the music on the card seperately. Then plug it into your sansa and it will recongnize the songs and play them like normal
Jan 25, 2009 | SanDisk Sansa e250 MP3 Player
How to access SD micro card on sansa e250
I expected to find the new playlists on the SD card as a separate file to access and play. Instead the SD card songs show on up the Sansa menu simply added among the existing songs / artists stored in the Sansa. Its not a solution but they are there. Since using the SD card, my Sansa does databse refresh everytime it starts, whether SD card is in it or not.
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
Micro SD card is no longer recognized
make sure the card is 1 gb or less - a Sandisk card would be best since it's a Sandisk player
Jul 26, 2008 | SanDisk Sansa e250 MP3 Player
SD card wont let me add anything
I don't think that the sansa e250 supports sdhc cards these cards 4gb and up are only compatible with newer electronics
Jan 28, 2008 | SanDisk Sansa e250 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
Expandable Memory
If music won't load onto Micro Sd card:
1) go to settings
2) go to USB mode
3)change to MSC format
Now you're good to go.
Nov 03, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
only music can be put on the microsd card
Jun 29, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
