Question about Hoover Nextra HNF 2137 Front Load Washer
Draining & Spinning
My Hoover Nextra hnf2137 is not draining or spinning during the wash cycle. It is also over filling, which lead to a bit of a flood. Any thoughts on what it could be? I have 3 kids, therefor the machine is going 2-3 times a day, so expecting a bit of trouble.
  • james whistance Aug 20, 2012
    control panel gone!
  • Anonymous Mar 21, 2014
    Zanussi
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
Posted on Jun 07, 2007
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
Wont drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 14, 2011 | Hoover Nextra HNF 3157 Front Load Washer
The start delay flashes in the middle of a cycle on a hoover washer dryer nextra 6 . it drains but doesn't spin
Program error due to maybe a delay in the fill and drain cycle, Get the inlet and outlet valves cleaned( drain should be quick)
Now if during the cycle the program is cutting off voltage to the motor, then the control board can be faulty.
Check if the drive is having connection fault to stop the motor voltage.
Sep 14, 2010 | Washing Machines
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Hoover washing machine model HNF71683D not draining water
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Feb 28, 2010 | Hoover Nextra HNF 3157 Front Load Washer
How do I set the washing machine to spin only on a Hoover Nextra HNL662?
Adjust the timer to the end of any cycle. The pressure switch will recognize the water presence, and drain before spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 05, 2009 | Washing Machines
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Apr 13, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Hoover hnl 6166 not spinning
have you tried cleaning the filter at the bottom. remove the front plateat the bottom and there is a small round plate at the left. this has a screw in it. when you have removed this you give it a twist. a bucketload of water and gunk will come out. i found about 60p in 5's but when it was all removed it started to work again
Jan 07, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover Nextra HNF 2137 Front Load Washer Logo
738 people viewed this question
Top Hoover Washing Machines Experts
shaun taylor
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
