Question about Dell E172FP 17" LCD Flat Panel Monitor
Dell Monitor goes blank, green light still on.
My 3 year old Dell monitor goes blank after the computer has been on for awhile. The green light is still on. Moving the mouse, clicking enter, tapping the space-bar do not make the screen come back. Sometimes if I power off the whole computer and turn it back on, the screen will come back. Uninstalled and re-installed the video drivers, replaced the cord between the monitor and tower.... now what? Hopefull I'll get an answer before the screen goes black again!!! Eeek!
  • Tony2009 Mar 22, 2009
    I have the same exact problem...I replaced the 15" Monitor for $129.00 at staples for a nice 17" Monitor.
    I think the problem comes from leaving the Dell monitor powered on for extended periods of time and like everything else in the universe it wears out with time ..after all 3 years 24/7 is quite a bash on anything.
Had the sam problem and just unplugged the monitor itself "from power source" and plugged back in...problem solved.
Posted on Feb 26, 2009
    Sergeant:
    Champion:
  • 275 Answers
Try one thing this will tell you if there is a problem with the monitor or the system
start the system and go in to bios and than check out if u still loose display
and if yes than when u loose display disconnect the data cable of the monitor from the system and chk out if u see the self test on the monitor or not
the self test if the colour patern if u see that its nothing wrong with the monitor its ur system
if u do not see the colour patern ... monitor bad
if the colour patern is seen reseat the cpu heatsink , remove the display card (if any add on display card ) and reseat the memory cards
and if that doesnt work remove all the add on cards and than start the system on the onboard display
and than put the cards one by one u will get the culprit
Posted on Nov 20, 2008
  • 837 Answers
Have you tried connecting that monitor to another PC. It sounds like you may have a problem with the monitor itself (component failure, heat problem, etc)
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell E173FPc monitor worked fine yesterday. Today, the monitor only stays on for a split second and goes blank. The power light stays green. If we shut off the monitor using the power button and wait 10 to...
The power supply in the unit has died. This is a very common problem with this series of monitor after 2-3 years of use. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide posted on our site at: www.ccl-la.com Our guide gives parts values and location information as well as how to open the unit up. If you don't feel like doing the repair we also offer repair services, see our web site for details.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
My monitor screen goes black
The monitor is going bad. Either going to be a bad screen or a bad inverter. Also Since you tried it on another computer and its still giving you the same symptoms, you know the computers are fine. To be sure, try another monitor on your computer and if you get video on the new monitor then thats another way of verifying that the dell monitor is bad.
May 16, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor won't turn on without help.
Do you have a second monitor or can you borrow one to check if the fault lies with the monitor or the PC?
If the monitor is at fault then there is not much you can do yourself. I suggest you contact Dell and get them to replace it under warranty. Most LCD monitors have a 3 year warrantly, at least they do in the UK.
cheers
Aug 04, 2008 | Dell E177FP LCD Monitor
1 year old dell monitor
Dell monitors separate 3 year warranty. call tech support at 800-8228965. have the monitor replaced.
hope this helps.
thanks.
Jan 09, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell E172FP 17" LCD Flat Panel Monitor Logo
720 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
