Question about Averatec 3200 Notebook
Averatec 2300 screen image 'whites out' or colored pin stripes
Recently our Averatec running on Vista started losing the screen image through a 'whiting out' of the image and/or a mass of vertical coloured lines obliterating the normal image... this seemed to be time related viz after progressively shorter periods of being on, the problem would arise... and there may also be some connection to the angle of screen tilt, viz certain 'sweet spots' that would return the lost image. The techie at a local PC shop says it isn't a screen problem because there is a good image to start with... he believes the problem is with the VGA card. Problem is that Averatec isn't supported here in Africa. Has anyone else experienced this problem and any suggestions how I could fix it?
Dylan from South Africa
  • amoits12 Nov 26, 2008
    bottom half of the screen has permanent coloured pin stripes
  • Averatec Master
  • 5,568 Answers
Just for the sake of information, the white of the screen means the backlight is working. LCD displays work by allowing light to pass through at different wavelengths, creating 'color.'
I doubt that your system has a separate, replaceable video card. This sounds a lot like a chip has developed and thermal problem. If you can buy 'freeze spray' there, try shooting it into various openings of the case when the problem is present. If this affects the display, you are probably going to need a replacement motherboard since the majority of the chips (ICs) are placed by robots and nearly impossible to replace by hand due to the pin spacing that is typical for modern ICs.
If you are courageous, you can get the case apart with 'jeweler's' screwdrivers. You will find that the screen assembly is connected to the main board via a flat ribbon cable that is likely stuffed into a questionable connector. You might try carefully pulling that cable from the connector and even more carefully, plug it back in again. Unfortunately, few companies are using any gold on connector contacts anymore and the materials used may oxidize and cause the kind of problem you are having.
Posted on Nov 20, 2008
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
Rainbow stripes and color changing box
If the screen is damaged, then no there nothing you can do without replacing the screen BUT then is it really damaged? I would try and see if a normal image is displayed on an external display via the laptops VGA port and cable. If good than it is most likely the screen BUT I would look into (By pulling the screen covers off, etc to see if all cables from the System board to the screen is connected properly, if they are and also same image is on the external screen then the graphics chip is the culprit...depends on how hard and at what angle etc did the Laptop hit the foot-board.
May 01, 2013 | ASUS Eee Computers & Internet
FAINT VERTICAL PIN STRIPES MOVINGS TO FULL AREA OF SCREEN
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 16, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Ned to wire speekers to my xr 2300 radio
As long as it is a newer model sony the speaker colors are: left front: white. left rear: green. right front: gray. right rear: purple. The black stripes are your negatives, solids, positive.
Aug 17, 2009 | Car Audio & Video
White vertical stripe on color images when they're printed
You may have some dust on the imaging window (printer head). Remove the toner cartridges and clean it with some tissues.
Apr 28, 2009 | Konica Minolta magicolor 2430 DL Laser...
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
Underexposed, grainy images with a light stripe running down the center
Sounds like your shutter curtain is malfunctioning. Did you bump the curtain when u loaded film & bed it... Take a close look to see if it is binding. This is a very fragile area to monkey with & should be done by a qualified repairman
Jun 26, 2007 | Canon EOS Rebel K2 35mm SLR Camera
Averatec 3200 Notebook Logo
277 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
