There must be lot of dirt and dust on the coolant tubes running from compressor in the rear. To solve that...do the following.
Disconnect the refrigerator. Pull it out so you can access the rear bottom end of the fridge where you can go to the black compressor. You will find tiny tubes running on black flat curved sheets. Feel the tubes and clean the entire area with cleaning solution or water with a damp cloth.
After cleaning and drying, connect the electricity and the fridge will work fine.
Mild soap and water with a microfiber cloth with TV off. Then I wipe only water on the cloth to remove any residue then quickly dry with a dry microfiber cloth.
I understand that your Frigidaire dryer is leaving your clothes warm but slightly damp. I will be more than happy to assist you. So I am able to better assist, I kindly ask that you provide me with the model number of your dryer. Typically, this number is located on the back of the door, or possibly around the edges where the door meets your appliance. Looking forward to hearing from you.
if the clothes are damp then I would disconnect the vent tube, and dry a load of clothes. If they are dry then the vent needs to cleaned. Hope this helps Tim
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
Make sure the correct Cycle has been selected for the type of fabric being dried.
If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time. Note: This change will affect ALL Auto Dry cycles.
Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
