Question about GE JRP24 Electric Double Oven
Bottem Oven Over Heats
GE double oven model no JRP24BOW4BB, Serial no. ST629695Q
Bottem oven seems to overcook everything. Could the heat senser or thermostate be replaced to fix this problem? What would the part no. be and where can I order it? Thanks Jim
    Welcome Back:
    Visited the website for 2 consecutive days.
GE announced a recall for some of its wall ovens this week for an overheating problem. Have you contacted a GE dealer yet?
Posted on Nov 20, 2008
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
GE double oven wall, JKP85B0A3BB
I would start by checking all of the door switches. Once you remove the shell, you will see them all on a rail where the door latch goes. Some will be normally open, some normally closed. If they all check out, check all of your overloads and thermal fuses. They should all read closed. If they all check out as well, replace your magnatron, capacitor, and diodes.
Oct 25, 2008 | GE JKP85 Electric Double Oven
GE double oven - bottem will not heat, top oven fine
I had a similar problem. Solved mine by resetting the manual reset thermal switch. The switch for the top oven is located behind the control panal which can be removed easily by taking out three screws then lifting up an leaning out. The switch has a red reset button, just push it in till it clicks.
The lower oven switch is located behind the vent grill between the two ovens.
GE should be ashamed of hiding this feature-it isn't mentioned in the manual. I discovered it on a schematic hidden behind the control panal.
Good Luck, DVS1936
Oct 05, 2008 | GE JKP45 Electric Double Oven
Never used Convection JTP 5650DI55
Did you try going to the GE website? If not, try it:
When you pull up the website, you can click on the blue down arrow located in the box at the top of the web page, next to the work SEARCH and click on "USE & CARE MANUALS. Put your model number into the next box to the right and hit GO.
If you are having trouble after entering what you believe is the proper model/serial number, you can look at the FAQ (frequently asked questions) section to determine whether you have actually entered the proper number.
Aug 05, 2008 | GE Profile JTP56 Electric Double Oven
Oven low heat
Did you try going to the GE website to pull up the Use and Care Manual? It does have a section re: how to adjust the temperature by as much as 35 degrees either way. Although it is not the 100 degrees you mentioned, you could try it and see if it helps...
The main GE website is:
At the top of the web page is a SEARCH section. You can click on the blue down arrow in the first box and select Use & Care Manuals, then put your model number in the empty box to the right of that selection box, ie. JT952 is my oven.
If you are having a problem locating your model number/serial number, you can go to the FAQ (frequently asked questions) section to see how to find it.
Jul 05, 2008 | GE Profile JT952 Electric Double Oven
GE Double Oven JKP45BA, lower oven wont heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
Jul 30, 2007 | GE JTP48 Electric Double Oven
GE electric double oven
Colin, the TCO is located on the back of the oven. It will open L2 to the heating element in the event it is open. If this TC0 opens it will not show any error codes. This is for the 27 inch wall oven models only. back.
Nov 09, 2006 | GE JTP48 Electric Double Oven
Open Questions:
See all GE JRP24 Electric Double Oven Questions
GE JRP24 Electric Double Oven Logo
318 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
