Question about Dryers
Dryer no heating, air flow good..
I have a Whirlpool
MOD: LEG8858HQ0
SER: MJ3622302
TYPE: DWSP-ELE-2406028-CVSA
I already open the back of the dryer, now my question is how to check which part is bad, I have a multimeter and I check part by part, but I'm not sure what's the readiong I should get. When I was checkig I got some readings like 0.03, 0.05 and when I check for resistant in the actual heater it only shows like this ( l . )
Thanks for your help.
By the way my e-mail is: perezf@pamf.org
  • Gamoneda Nov 24, 2008
    Thank you so much Rickzilla!!
    I followed your instructions and acording to the measurements on the multimeter, the Heat Element was bad, and sure it was, after I removed and noticed one of the wires was broken...
    I went and buy the replacement, my dryer its working like new..
    Thank you so much....
Serial number mp2803515 whirpool dryer that is not heating up. it spin, but blow out clod air olease help
Posted on Feb 06, 2009
  • crjohnson5 Feb 06, 2009
    ler5635lqo no heat from drier whirlpool brand
  • 706 Answers
Happy that your problem is solved.. Good Luck..
Regards,
Rick
Posted on Nov 24, 2008
  • 706 Answers
Hello Gamoneda,
Since you are already able to access the components in your electric dryer..( Always remove or disable power before taking any measurements like this).. Unhook the heater element itself and measure for continuity through it. You will probably get somehwere between 5 and 20 ohms ( model specific) when that element is cold. You could also have a bad upper limit thermal switch or non-resettable fuse has opened but if you are measuring any of these components for continuity.. make sure you detach any wires that are plugged into them.. If you don't do that, then you could might get false measurements by reading something that is wired in parallel with them. Hope this helps..
Regards,
Rick
Posted on Nov 22, 2008
Have a Kenmore Elite Dryer that won't start. Mod 110.65962401 Ser MS0303258 Type DDOT-ELE-2406028-CV54
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Electric Dryer , 700 series, MOD 64722400 , SER MR4136705 , Type DWJR-ELE-2406028-FM64 . Dryer is not heating, checked fuse it's fine, cleaned every nook and cranny with a swifter duster and...
Hi.
Be sure that you have checked the thermal fuse. The part is tested using a multimeter set on Ohms (impedance). Remove the fuse from dryer and read impedance touching the fuse contacts with the two multimeter probes. If impedance is Ohm infinity (open), then the fuse is bad.
If the fuse is OK because tested good or replaced, then the problem is either one of the three thermostats located in the heating group, or the heating element. All parts are tested similarly to what described for the thermal fuse. If any of the parts read open (infinity), then the part is faulty. After finding the defective part remove all the lint from heating assembly and air duct. The lint causes overheating and blows thermostats, fuse or element.
Regards.
Ginko
Jul 14, 2011 | Kenmore 64722 Electric Dryer
I have a Whirlpool electric dryer MOD WED5540S!) SER MU2124790 TYPE DWJR-ELE-2406026-FM54 the dryer runs good, but will not heat. I have checked the air flow and its clear. I've checked all...
Limit thermostat , heres how you check thermostats Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. I strongly recommend that you test your thermostat at room temperature.
Jul 13, 2011 | Whirlpool WED5500S Electric Dryer
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
MOD: REX4635EW2 SER: MJ0922226 Type: D433-ELE-2406028-FM54 Won't turn on just buzzes when hit the start button. Have already checked plug in and braker box?
Remove the back panel from the control panel to access the start switch. If there are 4 wires on the start switch,replace the start switch.
Aug 18, 2009 | Roper Dryers
Dryers Logo
124 people viewed this question
Top Dryers Experts
