HP LP3065 Monitor Logo
Anonymous Posted on May 08, 2012
Screen goes black for a second or two every few minutes
I get a great picture but every few minutes the screen turns black for a second or 2.
Anonymous
Level 3:
  • HP Master 6,771 Answers
  • Posted on May 08, 2012
Anonymous
HP Master
Level 3:
Answers
6771
Questions
0
Helped
1779280
Points
21413
This indicates the inverter transformer is going or a capacitor issue.
5 Related Answers
Anonymous
  • Posted on Jun 26, 2007
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Anonymous
  • 56 Answers
  • Posted on Aug 15, 2007
SOURCE: HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Anonymous
  • Posted on Jan 11, 2009
SOURCE: Auto Adjustment keeps turning on every few seconds
I have had the same problem and now suspect that cleaning fluid from when I cleaned the screen may have seeped in. After a number of things I did over a period of 2 weeks the problem went away completely.
1. You may be able, if that is your problem, solve it quicker with a hair dryer at a distance (no melt down!)
2. Run HP diagnostics and clean the registry
3. Re- install drivers
Like I said I think 1 is the most likely. I went from every couple of seconds to completely solved.
Another possibility is that an MS update may have caused the problem and then another solved it.
Anonymous
  • Posted on Dec 09, 2009
SOURCE: I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
Joaquim Martins
  • 1128 Answers
  • Posted on Dec 23, 2009
SOURCE: screen goes black after 5 to 10 minutes of
there is a screen light board defective as inverter board. there are on the market, some inverter boards available to LCD Monitor, Check for diemen Company on this site: http://www.hrdiemen.es/products/esp/index_esp.php
2answers
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
3helpful
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
3answers
Screen goes black after a few minutes, switching off and on and picture returns then goes black again
I have problem with my monitor, it is automatically switching off and switching on for 2 to 3 minutes for every 15 minutes why ?
Please mail me the solution to [email protected]
SCREEN GOES BLACK AFTER 1 MINUTE
In electronics dust has nothing to do. cleaning will not solve your problem your problem is due to trouble in vertical section. mostly it is due to electrolytic capacitor in vertical section is defective.it is common problem. also check supply to vertical section. "THE SCREEN SHRINKS TOWARDS THE TOP OF THE SCREEN FOR A FEW SECONDS BEFORE THE PICTURE TURNS UPSIDEDOWN THEN TURNS BLACK." is called fold over. regards thanks
6helpful
5answers
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
1helpful
Black Screen/Viewfinder
Mine too! Thank you so much for posting this issue!!
1helpful
The picture disapears, though the monitors stays on - every few seconds
Check the cable connections on the back of the monitor and the PC it sounds like the connection isn't made properly make sure they are tight.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
