Question about Kyocera Mita KM 1510 Laser Printer
Kyocera/mita KM1510 copier
When I turn on my copier the "A400" messager flashes on the display screen. I've hada service guy come out and tell me it's the laser and only $5-600.00 would solve the problem.I'm not interested in paying that kind of money. Does anyone know if I can replace the laser and where one could be obtained? PLease advise.
  • Anonymous Jun 30, 2008
    le cambie el cartucho de toner y no me permite sacar fotocopias, permanece el foco rojo indicando que falta toner,
    que debo hacer
  • 36 Answers
Hytech in Florida repairs them. Also Ambassador Tech.
Posted on Nov 13, 2007
Unfortunately it is the laser unit that has failed. And these unit's aren't a servicable item.
Posted on Jun 13, 2007
7750 power on self test error. "please install config chip", "call service"
Did you ever figure this out? I'm having the exact same problem right now & can't afford to call in a service guy. If you know, please send a message to karen@cre8ive.com. Thanks!
Feb 02, 2013 | Xerox Phaser 7750DN Laser Printer
What does a400 mean?
A400 is a laser related problem. Solution is to replace the laser unit
Jan 03, 2011 | Copystar CS-1505 Copier
Ricoh 3800c call for service
On the screen where it says "Call for service," there should be an error code (starting with "SC" and ending with a 3-digit number). This code can tell you what is wrong with your machine -- what code is displayed?
Does turning the machine off (with the main, orange power switch) and then back on clear the error message?
Feb 11, 2010 | Ricoh Aficio 3800CMF Laser Printer
I need to know what error code A400 means?
a400 is a trouble code for Laser Scanning Unit problem.
Jun 24, 2009 | Kyocera KM-1510 Copier
A400 SHOWING ON DISPLAY
Laser diode is not working. Needs a laser unit (expensive)
Apr 21, 2009 | Kyocera KM-1505 Copier
Hello- We have the Kyocera KM 1510 and have an error message A400 coming up on the printer. No functions will work..do you have a suggestion or what would cause this problem. The toner cartridge was just...
Inside the printer, in the laser assembly, the zoom motor is not working anymore. Try to open it, stay clear of the lens, remove the little board with the motor atached to it, open the motor and clean it. Normaly it should run smoothly. i had the same problem, solved it, but now i get the A100 message. Any ideas?
Jan 29, 2009 | Kyocera KM-1510 Copier
Error message A 400
I'm sorry to say that it's probably the death of your 1505!
It just might be too expensive to repair, the code A400 relates to the polygon laser motor, which could mean changing the whole laser assembly, or the power source board, either way it's going to cost you. BTW, the 1505 was discontinued in June 2003, what's available today has more features at 1/2 the cost. Happy hunting...
Sep 09, 2008 | Copystar CS-1510 Copier
Copier refuses to copy
this is a laser motor problem unless you knew how to removed this and inspect it most likely it is damaged or faulty, try resetting the machine for a while if not you need a tech guy to replace this
cheers
Aug 30, 2008 | Kyocera Office Equipment & Supplies
Whirring sound after start then black screen with E18 in bottom corner
this is very easy to fix- switch your camera on, grab then lens around the edges, and carefully give it a firm twist. It should click and turn on.
Dec 18, 2007 | Canon PowerShot A400 Digital Camera
Kyocera Mita KM 1510 Laser Printer Logo
349 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
