Question about Lenovo ThinkPad R51
Blinking LCD on IBM Thinkpad R51
It constantly is blinking, but you do see the screen. But the lower left hand corner, near the Start button is starting to shade black and get hot. Do I need a new LCD and is it worth putting this money out?
I pressed a little square button on left top conner and the screen went dim, how do i solve this problem
Try FN blue button normally down in the lower left corner of the keyboard and arrow up key or it looks like a blue light up. Push both of these keys at the same time to see if this increases the brightness back up.
Oct 03, 2013 | IBM ThinkPad R51 Notebook
How to trun the WIRELESS not the BLUETOOTH on in a R51 Thinkpad
most laptops and thinkpads have a physical switch to turn them on and off some do not. to turn them on you have to first push and hold "Fn" key in the lower-left corner of the keyboard, then push the "F5" key at the top of the keyboard. the wireless indicator light should now be on
Aug 21, 2012 | IBM ThinkPad R51 Notebook
Can you please tell how do i switch on wi fi in IBM think pad r 51
  • Push and hold the "Fn" key in the lower-left corner of the keyboard.Push the "F5" key at the top of the keyboard. The wireless indicator light should now be on.
  • Apr 26, 2012 | IBM ThinkPad R51 1830 (1830AHU) PC...
    Lcd is very dim. after changing res a glow in the lower right corner starts then back to darkness. It works fine with my vga monitor.
    Hi, display DIM cause by LCD or inverter Board (brightness controller). Might costly. Up to you either want to change it or not.
    And using external monitor is best solution, I think so. =)
    May 08, 2010 | IBM ThinkPad R51 Notebook
    IBM thinkpad t42 boot up problem.
    The most common reason is memory.
    First, try to reseat (remove and reinsert).
    If still a problem, test one module at a time.
    Hope this helps.
    Aug 17, 2009 | IBM ThinkPad T42 Notebook
    Hand-me-down IBM Thinkpad 600E 2645 has blinking LCD video XP O/S
    This sounds to me like either your flourescent lighting tube is beginning to go bad ,,, or the inverter is going bad ... or even both. :-)
    The cheapest and easiest solution for you is to simply replace the LCD screen (replacing the inverter or the tube are actually a bit cheaper, but not quite as easy to do - most computer repair centers will try to talk you into a new screen anyway). This is actually very simple for either you or someone you know who is an avid "do-it-yourselfer". IBM makes ity very easy. You will find easy, detailed instructions in the ThinkPad 600/600E (2645) Hardware Maintenance Manual, IBM S10L-9619-03 June 1999 available for FREE downloading in .pdf format on IBMs website. Follow this link to some really sweet deals on LCD screens for your 600e on eBay for under $35.00. http://shop.ebay.com/items/?_nkw=ibm+thinkpad+600e+lcd+screen&_sacat=0&_trksid=p3286.m270.l1313&_sop=12&_dmpt=Vintage_Electronics_R2&_odkw=IBM+tube&_osacat=0
    Remember you can always connect an external monitor to your ThinkPad until your new screen arrives if you have one. The manual should also give you instructions to change out the tube if you wish to save a few more bucks and try that route. Hope this will FIX-YA! Please leave your feedback and let me know!
    Jul 27, 2009 | IBM Computers & Internet
    The left mouse button does not work on my IBM
    Windows has the ability to swap mouse buttons, mainly for those who mouse left-handed. It looks to the right button for left button action. It seems that the actual left button is not functioning. A work-around is to use the right button as the left as you are now doing, AND, use the solid windows button (the one to the immediate left of the right control key) as the right button. Not as easy, but it works.
    Jul 18, 2009 | Lenovo ThinkPad R51
    I want to no that wich ram short for the IBM thankpad r51 model
    I request you about IBM ram that is short to IBM thinkpad R51 model is 256 MB.
    Apr 27, 2009 | IBM ThinkPad R51: R51 P M 745 1.8GHz,...
    R51 thinkpad display problem
    I think the LCD screen is not working properly. The only solution is to replace it.
    You can find replacement LCD screens for IBM R51 here:
    http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
    May 27, 2008 | Lenovo ThinkPad R51
    Computers & Internet Logo
    143 people viewed this question
    Top Lenovo Computers & Internet Experts
    Michael Vincent Cruz
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
