Question about RCA D52W19 52" Rear Projection Television
Replacement screen for RCA d52w19
Need a new screen for this model, I think it is discontinued but is there a screen that will fit it? I need the outer part as well as the vinyl part.
  • garrettj Nov 20, 2008
    it is D52w19byx1 Thanks.
  • 1,030 Answers
You will need the entire model number to see if the screen is avalible.. D52w19 + the ext number YX1 or yx2 or something like that it will be on label as model number but in smaller letters.
Posted on Nov 20, 2008
  • Willie Howell Nov 20, 2008
    ok the part number for screen is rca # 258513 the outside one is 258797 Now the bad news the screens run 300 and the outside is 86. of course this is with my distribtor union electroncs. i suggest googling the part number
I have an RCA 52 inch Model d52w19. It makes a sparking sound when turning on and I can see electricity flowing from what I think is a flyback soldier.
thats a common problem where the flyback will need to be replaced. The RCA repair kit called the 259296 flyback is the correct flyback for your model from the flyback comes with installation instructions.
Sep 25, 2011 | RCA Televison & Video
I cracked the screen of my model d52w19 tv where can I find a replacement part
The part number is 258513. I found a new one at for 281.09 which is kind of pricey.
298.99 at, MCM shows one in stock for 174.48. That seems to be the cheapest new one I could find. Heres the link. You can also try ebay for a used one. I wouldnt pay over 50.00 for a used one..
Oct 17, 2010 | RCA D52W19 52" Rear Projection Television
RCA D52W19 Flat Screen TV capacitor 2200/16 needs replacing. But I can only find 2200/10. Think this is good enough or should I go higher in voltage like 25 or higher?
the common practice is never go down in voltage rating. as a technician i would defintly not go down to 10 volt i suggest you go up 25 would be ok if you can get it to fit
Oct 16, 2010 | RCA D52W19 52" Rear Projection Television
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
Well, i lost the front of my tv moving it. it was destroyed, now i'm looking for a replacement but don't know what it's called. could someone tell me? is it the screen? Panel? I don't have a clue, searched...
if it's the lower front, then you need the speaker grill, if it's the upper front then you need the screen assembly, if it's the middle front, then you need the control assembly, these are very common tv's, you could probably pick one up off craigs list or some websight just like yours but don't work and get the housing parts cheap, new, they might not be available since they are considered cosmetic parts and are discontinued early on in the life of the set.
Sep 07, 2009 | RCA D52W19 52" Rear Projection Television
My rca d52w19 has a cracked screen,
is the inner screen damaged? or just the outside. the outside is called the super sheild. this can be purchased at union electronics
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Replacement Lamp
If your model is the D52W19 you dont have a lamp you have three CRTs ( picture tubes) instead. What is the symptom? I have a good source for RCA parts. Please respond to this same post and if D52W19 isnt your correct model number please post that as well and I will assist you with your set.
Aug 04, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w19 screen scratches
the front protective screen in which rca calls a supersheild. can be replaced quite easy. it cost u bout 70 dollars. a cheaper solution i have heard of is to replace the screen with a thin plexi glass. thats if the internal screens have not been damaged.
Jan 01, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
102 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
