Question about Mitsubishi VS-45605 50" Rear Projection Television
Mitsubishi VS 45605 won't turn on
When trying to turn it on, the green power light goes on and then off, but the screen does nothing. Why won't it turn on?
  • 3 more comments
  • Tim Munsey Nov 20, 2008
    I have the same problem with my Mitsubishi WS55711...............
  • Anonymous Nov 28, 2008
    We are having the same exact problem with the same model VS-45605 Television set. Does anyone know how to fix this?
    same exact problem with mine as well... I thought there might be some type of lock on it but I have pressed every combination of buttons I can think of.
  • JohnyHotnuts Dec 06, 2008
    Try to turn on and goes off. i have a service manual but no mention of this type of problem. Please help
  • Anonymous Jan 05, 2009
    no power at all
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-45605 rear projection tv
If the green light is not lighting up, you will need to check out the standby power supply inside the TV set, or if this set has a DM board, you will need to change the capacitors. Good Luck
Posted on Jul 14, 2007
  • 1153 Answers
SOURCE: Mitsubishi VS-50607 Won't Turn On
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Posted on Oct 06, 2007
  • 126 Answers
SOURCE: Mitsubishi 60" Model VS-6047
going into shut down why well ther emay be couple reason bad voltage regulator no b+ relay bad or open solder joints call tv reair shop
Posted on Feb 19, 2008
SOURCE: veertical lines
Put a fan in it. Something is overheating in the unit and by placing a small fan in the back, inside the back cover, the lines disappear. Hope it works for you, it did for me.
Posted on Oct 24, 2008
freetek
  • 5568 Answers
SOURCE: No power on 2002 Mitsubishi VS-60609
You've mad the right decison; fuses can fail due to metal fatigue as they flex a little each time current flows through them of ceases but a 2nd fuse is unlikely to fail instantly. This indicates a true problem.
If you found the fuse, it was probably located on the main power supply board and this item has likely failed.
Look for an assembly number on that board and call a Mitsu service company and inquire about repair or replacement cost. Either one can range from ~$75 to $150.
It would be interesting to know if the fuse blew as soon as the unit was plugged back in or only when you tried to turn it on with the remote or power button on the set.
If it blew only by plugging it in, that power board is the culprit. If it blew as you tried to turn it on, it could be a failed 2nd power supply for the CRTs that is often located separate from the main supply where the fuse was.
About any E-tech could ferret out the which of the two is at fault so you might consider having a pro do the repair but if you know the failure sequence you might choose to gamble on making the decision yourself.
Good luck-
Posted on Jun 19, 2009
It comes on and then it goes off
This just happened to me as well. Keep it plugged in for about five minutes without trying to turn it on. Then try. This will ultimately tell you that your convergence chip is out. If the screen comes back on, it will look distorted. This is most definantly that chip going out. I suggest a tv repair kit or trash it. You can find a vs 45605 here: http://www.tvrepairkits.com/xcart/vs-45605/
Jan 17, 2013 | Mitsubishi VS-45605 50" Rear Projection...
Jul 13, 2007 | Mitsubishi VS-45605 50" Rear Projection...
We lost power the other night. Now I have a continuous green blinking light and it won't turn on. I have tried everything the manual says.
Try Going To The Mitsubishi Web Site. Downloading The Mitsubishi Service Manuals If You Don't Already Have It. It Will recommend The parts You Need To ordering. Circuit board photos are also shown which provide a visual reference during the repair process.
If you decide to have a service technician do the repair, insist that the "DM" module is removed from the TV and ONLY the four 1000uF, 16V Capacitors (Caps) located on the DM Module are replaced. MOST techincians will INSIST on replacing the entire DM Module and not simply the capacitors. The cost is about $200 for a technician to replace the capacitors and $1000 for replacement of the DM Module. As you will read below, doing the repair yourself will cost less than $4.00 for the 4 Caps.
Sep 04, 2011 | Mitsubishi WD-52525 52" Rear Projection...
When I turn on the tv I see the green light power come on and then it will just shut off right away
Depending on actual model number most of these sets have a self check.
When green light goes out: On front of set press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat several times.
Let me know what error code you find and comment here and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Oct 05, 2010 | Mitsubishi Televison & Video
Powers on to blue screen and nothing else
press the input button until it cycles through all of the inputs.
Feb 11, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi big screen vs45605
I believe I have a convergence problem with my VS-45605, i cannot get the front panel controls to move the blue and red crosses. I dont have original remote and a universal remote doesnt work either, any suggestions.
Jul 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
VS- 60705 Red,green,& blue lines all over screen.
sounds like your screen controls are too high? thay are behind the front cover 6 contols 3 for focus and 3 are screen the screen controls.
Apr 12, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
