Question about HP Pavilion zv5034US Notebook
Problem with AC plug in on the back of the computer
When I plug in the ac power pack into the ac in spot on the back of the computer it does not connect and power up the computer. Sometimes it will switch from battery to power but will not stay connected for more then a few seconds.
LLSouth
    Sergeant:
    Champion:
  • 274 Answers
Either your adapter is going out, you have a broken wire in the cord, or you have a broken solder on the computer connector.
Posted on Nov 20, 2008
Need AC power cord for task force model 202754 tire inflator
This a battery jump pack that is used to jump start a car. Some units have an ac adapter built in so you can charge the battery in the jump start pack. My unit has a spot to connect the ac adapter to the jump pack so you can charge the battery in the jump pack. My ac adapter has been lost. I know I have to buy a new ac adapter so I can charge my jump pack, what I do not know is if the input (from the ac adapter) is 120v 60 hz
I understand that the DC output needs to dc12v. I do not understand the milliamps. The battery in the jump box is 12v 10 ah ( what ever that is). I just want a new ac adapter to charge the jump pack with that is not going to damage anything.
Oct 19, 2017 | AC Cars & Trucks
Dell latitude 610 AC adapter issue or battery pack issue or both?
It could possibly be the power jack that is inside the computer. This item is typically soldered onto the motherboard and it is what your ac adapter plugs into.
Dec 21, 2007 | Twinhead SlimNote N12PI Notebook PC
Asus1000ha flashes between AC Mode and Battery Mode
Based on your explanation I will try to answer your problem.
It seems you have a problem with charger regulator. When you plug your charger into AC outlet then this regulator will detect the current that flows through voltage sensor then the Vreg pole will command the regulator to open charging circuit.
In plain English: Your computer has a problem with power regulator IC which located near the battery poles.
Aug 11, 2017 | ASUS Eee 1000HA PC Notebook
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
Computer was on AC power. Left unattended it shut down. Would not wakeup. Shut down fully, it would not come back up. Get a 2 short beep code. Invites an F1 to go to setup. Won't go to setup. Screen then...
Can you tell if your AC power cord is working? (Is there a light on the computer that comes on when it's charging?) If the power pack went dead, your battery could've died and now you get no power to the PC which is why it won't boot up.
To test, take out the battery and plug the AC cord in and try to boot up. If nothing at all happens without the battery, then your power cord or power pack is dead, and you just need to replace it.
May 29, 2010 | IBM ThinkPad T21 Notebook
Not charging
Remove the primary battery pack and travel battery pack (if applicable) and plug the computer
into an AC outlet using the AC adapter. If the computer starts up, one of the battery packs
may need to be replaced.
if the computer does not start with a/c power connected. ensure the power outlet is providing power, otherwise you problem may be the motherboard, cpu or memory. please provide more details (ex. lights on and color, any beep secuences heard, procedure attempted, age of computer, how the problem came to be)
Apr 19, 2010 | HP Pavilion dv6000z PC Notebook
Shut off and won't come back. It's like it is dead.
follow this procedure:
1. unplug the ac adapter and keep it unplugged.
2. Remove the battery and keep the battery unplugged.
3. Hold the power button down for 15-20 seconds(Nothing will appear on the display and none of the lights will light up)
4. Release the power button and plug in the ac adapter ONLY. (A power indicator light should be lit on the ac adapter when it is plugged in)
5. Normally power on the notebook.
6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
7. Plug the ac adapter back into the system, the battery charging indicator light will light up. If the battery indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Char S.
May 27, 2009 | Acer Extensa 5420-5687 Notebook
The computer does not seem to be charging up
I am a Dell Certified System Engineer(DCSE)
try taking out tthe battery and then try powering the system only on ac adapter connected
if it doesn't power on only on the ac adapter make sure that the port on the system where you plug in the ac adapter for any kind of bent or broken pins
if the port is ok then get your ac adapter replaced.
Jun 10, 2008 | HP Compaq nx9020 Notebook
Computer start-up
ok...try this without battery, only with ac power pack plugged in.
got backup?
Feb 11, 2008 | HP Compaq Presario V2000 Notebook
Supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Dec 27, 2007 | Supersonic SC-299TDVD
HP Pavilion zv5034US Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
