Aiwa AV-D57 5.1 Channels Receiver
Problem for Aiwa AV-D57 5.1 Channels Receiver
Sound problem
By mattt on Dec 17, 2006
I am running an explorer 3250HD cable box and I am using an optical audio cable from the cable box to my Aiwa receiver. The problem I am experiencing is that the receiver will momentarily switch from the digital signal to analog. This will cause no sound for just a second, but it is kind of annoying. The light on the display will switch over to analog and then right back to digital. all my connections are tight. Could this be a defective optical cord? or might there be another issue here.
Solution #1
posted on Feb 20, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I'm fairly certain this is a cable signal issue... I have had my digital audio cut in and out and the cable company traced it to a weak signal and replaced the cabling. No issues since.
Just an FYI, my setup is a Sony 6.1 with an Optical cable. There is a Blue Light indicator for Surround and when I had the problem, the receiver's light would go off and the display "blinked."
Popular Solutions for Aiwa AV-D57 5.1 Channels
Questions and Unsolved Problems for Aiwa AV-D57 5.1 Channels
Do you recommend Aiwa AV-D57 5.1 Channels Receiver?
Answer
Answer
necestito activar el sub-wofer, no tengo el de control remoto del equipo.
Answer
when i went to turn it on it went into test mode ,now nothing ,how do i get it get out of test mode?
Answer
The receiver use to turn on but then turn off randomly, ant the little ECO led light would come on.... (More)
Answer
I cant set the explorer 3250hd to video so i can watch my videos. please help!!!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Aiwa AV-D57 5.1 Channels...:
Top Receiver Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Receiver Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
