Question about Dualit Vario 3 Slices Toaster
Heating elements turn off while timer is still running
This 2-3 button is red when the heating elements are on when the timer is running. Most of the time the light turns off and stays off. I have to turn the timer back to get the light to turn back on which in turn, turns the heating elements on. Is it possible I need a new timer??
I have a 3 slice toaster #30157
  • 37 Answers
Ask the service center at;
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700---Steve Karow
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Nov 20, 2008
My Kenmore HE4 electric dryer runs for 2 minutes and stops
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replac it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Oct 01, 2013 | Kenmore Elite HE4 Electric Dryer
Frigidaire AEQ8700FGO dryer will run (and heat) for about 30 to 60 seconds then stop. 3 lights above start button will flash rapidly. Depressing cancel and start buttons at same time will not work for...
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
Sep 30, 2013 | Electrolux AEQ8700F Electric Dryer
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
Dryer not heating
usually when the dryer is not heating is because the heating element has break. you can purchase a heating element kit with insulators at a parts appliance store.requires taking the dryer apart and removing the drum. the heating element is behind the drum. if your handy you should have no problem. good luck!
Jul 25, 2010 | Roper REX4634KQ Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
The drier spins but no heat
There is typically not a reset for heat.
Some MAY have a t-stat that has a small red button in the center that can be reset, but doubtful. If so, you need to find why it over-heated.
That said, there are many causes for not heating when it still runs.
1) Power. Motor runs on 115 V, heat on 230 V. If you have partial voltage to the dryer, this will cause your problem.
2) Heating system has many components in series, any one of which will cause the problem.
  • Motor start switch
  • Thermostats, high temp, run temp, etc.
  • Timer
  • Heating element, (most likely)
  • Wiring to all compontents
These are a few ideas.
Gary
Nov 30, 2008 | Hotpoint Dryers
No hot air
possible voltage issue be sure you have steady 240 at 2 outside screws on ac connection next ck timer quick ck unplug dryer remove console cover short large red and black wires together plug back in and turn on ..possible motor switch ..contacts in motor switch close as motor runs supplying one side of element with other 110 volts
Nov 27, 2008 | Kenmore Dryers
Dryer will not run
ck thermal fuse located on blower housing at rear should be white object with 2 blue wires ..if cks ok ck door switch
Sep 26, 2008 | Kenmore 63012 Electric Dryer
Keeps heating on cooldown
needs new timer switch
the timer swithc contains 2 switches one for the motor and one for the heating element, the element switch has fused closed. not reliably repairable,
even if open the timer, break apart the contacts, file them smooth, reassemble, will still lock up again
replacement is less than a new dryer
Sep 05, 2008 | Whirlpool LER4634J Electric Dryer
Dualit 2 slice toaster
The top red button is the heating element selector.
If you push it to the left, only the left side is going to turn on.
Push it to the right and both of the heating elements will turn on.
Idea behind this comes from the commercial background where you save electricity on using only the elements that you need.
the bottom is simply a timer.
you can get an instruction manuat at:
www.dualitusa.com or email your request to:
irene@smithagy.net
Jun 19, 2008 | Dualit 20247 2-Slice Toaster
Dualit Vario 3 Slices Toaster Logo
165 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Angel Joseph Jr.
Angel Joseph Jr.
Ross Keen
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
