Question about Cooktops
Changing the surface burner spark electrode for GE stovetop
How to change the electrode
need manuals or DIY help
GE Stove top burner JGP326WEv1WW
  • gmr8 Jan 28, 2009
    I appreciate the diragram but that doesn't help me on exactly how to replace it. I have removed the burner and pulled up in the electrode but not sure how hard to pull or if it even comes out this way.
  • Anonymous Mar 11, 2009
    I have the part but how do I change the Electrode? Do I need to remove the burner?
  • 338 Answers
Schematic -
Posted on Dec 07, 2008
Where can I buy the stovetop burner gaskets?
  1. Gaggenau Range/Stove/Oven Parts - Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
Jul 11, 2015 | Gaggenau Cooktops
How do I plug back in the GE stove top burners after unplugging them?
The two leads from the burner fit into a socket in the stove top. It's a bit tricky to get it in just right. If the three metal "legs" on the burner fit snugly into the three slots on the stovetop you did it right.
Aug 26, 2012 | General Electric Ge Stove / Oven / Range...
Igniter works, but the clicking doesn't stop
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part
Aug 11, 2011 | DCS 36 in. CP-364GD Gas Cooktop
My front left ignitor/electrode is continually igniting on its own. How do I get it to stop?
Somethings when we clean the cooktop with a damp rag especially around the knobs moisture can get onto the burner switches. When this happens it creates a short and spark the electrodes. Try to unplug the unit for 24hrs. I have had so many just dry out and never had a problem. If you try this and still get the clicking change out the wire harness part#WB18T10339. Its a series of switches that sit on top of each burner and connected to the spark module. I would recommend changing out the spark module part#WB13T10046. Both of the parts are only around $20-$30 a piece and you will have your cooktop running like new.
Please look at item numbers 323,318 on the picture thats what needs to be changed out national_a_r.png
Please rate me a "4" if I helped you. Have a super day!
Dec 14, 2010 | GE 30 in. JGP328 Gas Cooktop
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
Feb 05, 2010 | GE 30 in. Profile JGP979 Gas Cooktop
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
GE gas stove top igniters won't stop clicking
My wife just called me with the same problem - all 4 starters are clicking repeatedly - which started while the range was being cleaned.
From a Google search, this is what I found. Don't know if it will solve our issues, though wanted to share as it sounds like we may all be suffering from dirty starters (electrodes).
My surface burners keep "clicking" even after the burner is lit. There are a few things to check for.
And, to check the model number, look at the various places pointed to in the upper left of this diagram.
Oct 18, 2008 | GE Profile JGP636 Gas Cooktop
Cooktops Logo
1,512 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
