Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
SONY KP-57WV600 - Small green lines across the screen
I have a 6 year old Sony KP-57WV600. The picture still looks great. However recently there are small green lines that span across the entire screen (horizontally) showing up. They are only noticable when changing channels in the delay between channels, a plain black screen comes up and then you can see the green lines. You can only see it for a couple of seconds as you are changing channels. The green lines also show up when watching a DVD and the movie has a lot of black background, etc. I have unplugged and replugged all electrical cords for all components. Also, this doesn't show up when you first turn the TV on. After 30-45 minutes or so, the green lines begin to show up. Any ideas on how to fix the problem?
  • OKKJ Jan 29, 2008
    I too have the same condition. The lines are noticeable now while it is on, in any mode. A closer eval shows the lines to be in an arc, sort of like a rainbow effect. Help...!
  • Anonymous Apr 07, 2009
    I have the SAME probolem. Do we have a class action law suit against Sony here.
According to several sites, the problem is with the convergence via the voltage on the color ray gun tubes that get out of adjustment. They are also known as retrace lines
Sony wanted between $150-$300 to diagnose and fix -- instead I was able to complete this repair in less than 15 minutes!
Since I had been through the routine once more and I was sure others are running into this issue,
1. All you need to complete this guide is one flat-head screwdriver and one Phillips screwdriver as well as a delicate touch.
2. Front shot of the television. Their are two screw holes on the front of the unit near the edge of each side right next to the speaker grille.
SONY KP-57WV600 - Small green lines across the scr - 2_sony_projection_tv_front_screw_locations.jpg
3. Close up shot of the screw hold. It is covered by a plastic cover that has two tabs holding it in. Carefully pry them out with your flat head screwdriver. Do not apply too much pressure or you can break the tabs off. Once the covers are removed, unscrew the two screws with a Philips screwdriver.
4. To remove the cover, pull from the bottom of the front case and rotate towards you. Once you rotate it out, the top will disconnect and come loose. Do not pull it off, as there are cords attached. (see picture) Loosen the cables attached with the twist ties and set the front cover to the left side.
5. With the speaker grille and cover removed, you now need to remove the wood panel to expose the inner electronics on your Sony HD TV. To do this, remove the four Philips head screws from the panel. Then, pulling from the right, rotate the panel off and the electronics will be exposed.
6. This is a picture of the inner electronics of your Sony Rear-Projection High Definition television. The little black box towards the front of the unit is where we will concentrate our time as it is the control for the voltage & convergence adjustment.
7. When focused in on the controls, you want to concentrate on the bottom row for the voltage / ray gun projection adjustment. The colors are labeled below and from left to right are blue, green, and red. Choose the one that needs to be adjusted and turn ever so slightly with your Philips screwdriver to remove the lines. In my case, the red just needed to be turned 1/8 of a rotation to be back in adjustment. Do not turn to quickly or abruptly or you could possibly damage your TV by varSONY KP-57WV600 - Small green lines across the scr - 7_red_blue_green_voltage_band_adjustment.jpghttp://bp0.blogger.com/_0xPnZbi2QtQ/Rn7bY4P11uI/AAAAAAAACR8/mzXshejjEhg/s1600-h/7_red_blue_green_voltage_band_adjustment.jpg">7_red_blue_green_voltage_band_adjustment.jpgI hope this guide worked for you?
Posted on Apr 26, 2008
    Problem Solver:
  • 11 Answers
Go to this site, follow the instructions, and it should fix your problems. I did, and my tv is better than ever!
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
I was having this problem with blue. I was able to fix it, and now my tv works again. For those having trouble removing a different front panel, here is what I found on mine -
I own a KP57WV600. Removing the front panel is a little trickier on this model. You remove the 6-8 screws on each side behind the two speakers. You will access these from the lower rear/sides of the TV. Remove the small 2ft plastic pieces. Now from the front of the machine grab the entire lower piece (speaker covers & power/volume/chanel buttons) from the bottom and pull down and towards yourself. There are 4 slots that this piece fits into. I had to take off the lower back panel to see why it wouldn't come out. Don't pull to far because this lower front piece is connected to wires. I'd say you have about a foot of play. Now you can remove the fiber board panel and access the blue/green/red lower screws. When you adjust these, go a fraction of a milimeter at a time.
Posted on Apr 09, 2008
  • DayVihd Apr 23, 2015
    I have the same model, just bought off Craigslist for $100. Got it home and was so disappointed to see green AND blue arching lines all over the screen. I followed the steps listed here and now picture is perfect....well, for a rear projector TV it is. Thanks a million for this post and the one above!!!
    Scholar:
  • 119 Answers
I agree adjusted the green screen control JUST a little so the green lines are not visible on a black screen. to locate the screen/focus control assy. you must removed the bottom front plastic of the tv.looke of 2 to 4 screws, some may be hidden. then the plastic front will pull of. it will come out with some difficulty, just make sure you have all the scrwes. Then in the center remove the black wodded or plastic panel, usually 4 screws. now in the upper right side you should find a small black square with 6 adjustable controls. using a light look to see if the top three is the screen controls. ( i think it is.) If not it will be the bottom three. The green control will be the one in the middle, the other 2 are the red & blue tubes. good luck.
Posted on Dec 19, 2006
    Problem Solver:
  • 13 Answers
I think tha you nid check the screen controls [green] good luck!
How did I correct blue and red lines curved across a blank screen of my KP-57WV600 SONY Projection TV?
This is for if the lines are thin and arc.
You need to turn down the screen voltage for the blue and red CRT. I don't remember if the focus block is in the front or in the back of the tv on this model. Most projections have them in the front.
You could check the back access panel and look for a black box with six knobs as descibed in step 3 below. This is what you are looking for.
follow the steps below if it is located in the front:
1) Remove the front grill
2) There should be access panel you need to remove once you remove the front grill. This is where the screen voltage adjustment is located
3) Look for a small black box with six knobs on it. One row is for "Focus" and one row is for "screen". It will be marked, but probably need a flashlight to see which row it is. There will be a "R", "G" and "B" next to each knob to represent Red, Green Blue respectively.
4) Careful with the access panel removed, you are only inches away from very dangerous voltages.
5) slowly turn the R or B knob counterclockwise until the lines on the screen disappear.
Keep your hands away from everything else and only use one hand near the tv. put the other hand behind your back.
6) Once corrected, replace the panel and put the grill cover back on.
Feb 17, 2011 | Sony KP-57WV600 57" Rear Projection...
Arched lines in dark screens whether it's Cable or DVD playing Model number: KP-57WV600 Sony 57inch rear projection TV
Ur convergence it dead.Do u know how to solders? Tries these websites. Tv repair World.com or Tvrepairkits.com have it.Buy a convergence kit used what in that kit ur tv well get back to normal.The shop will cost u $300 for parts and labors.
Jan 01, 2010 | Sony KP-57WV600 57" Rear Projection...
Red lines across screen
had tv that did the same thing after three years but they were green cost me 300 bucks to get it fixed and the guy said every 3 to 5 expect it
Jul 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony goes blue
you need a new Blue CRT you can get them at the following link.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | Sony KP-57WV600 57" Rear Projection...
Sony kp-57wv600
hola al problema lo debes tener en los transistores de color que estan en en la plaqueta donde va el socalo debes tener alguno desoldado
Sep 24, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-57wv600 big screen
you will need to replace the Green CRT your model uses the sony # 873365201 CRT. The other site I work for just got a shipment of Sony and RCA CRTs(Tubes) in on friday. So you can get one at the following link these are brand new Tubes and they provide free shipping and free on line tech support with instant messageing in case you need help installing it. Heres the link.
Jun 22, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony Rear Projection TV - Red tube too strong
remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
May 16, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WV600 screen
I had the same problem except blue lines then all blue..I needed a blue crt tube..........so I'm assuming you will need a green crt tube
Jan 14, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
2,372 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
