My ibm desk top is stuck in power save mode monitor won't work
My desk top is stuck in power save mode. when i reboot i have no monitor I have tried 3 different monitors none will show the message says monitor is in power save mode activate using pc .
  • etwdocs Nov 21, 2008
    Thank you for your quick response however it did not work so I guess I will have the drive tested
    thanks again
    Eric Wade
  • Anonymous Jan 02, 2009
    I experience exactly the same. IBM P96 monitor and desktop pc.
    The same monitor displays everything fine when switched to my laptop.
  • 105 Answers
So the only way you have to act is, turned off and directly on the mainboard, so do it carefully.
You'll have to find out, where, on the mainboard is located the battery, (a small coin like
unpluggable metallic piece)
Remove it and let all static electricity completely disapear, so, let the cpu power unplugged,
battery removed, for 1h,
Then, place back, battery, try to start again if not working it's hardwaire failure.
Posted on Nov 20, 2008
  • Arnaud Gaudin
    Arnaud Gaudin Nov 22, 2008
    at your service...
    Niceday 'nyway.
Monitor stuck in safe power mode
"Power Save Mode" but it tells you to press a key or whatever?
were you able to reboot the PC?
if you can reboot the PC but no screen is showing up during Windows load (you can see the hard drive activity LED lighting up and your hard drive spinning), then, youre probably have a broken monitor.
Or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep. http://www.ezsystemrepairs.com/
Jul 01, 2012 | Dell Computers & Internet
I have an LG E2350V monitor. When I connect to my desk top PC, it starts to display the pc starting up sequence, then after 20 seconds or so goes into Power Saving mode and it wont get out of it. ...
Hi keepintouch0,
Make sure that the power save settings are not set in the OSD of the monitor , and if they are set to switch off after some time , then you need to change the settings as per your requirement.
Hope this helps ...:) Let me know in case you have any queries.
Aug 01, 2011 | LG Computers & Internet
Hello..just moved my desk top to new desk..everything is fine..but mouse won t work..while it was unplugged i cleaned keyboard..monitor with soft cloth..can u tell me why my mouse won t work
IF it's a serial mouse (meaning green round connector) it's probably not plugged in correctly. Now these are not plug and play so you need to reboot your system in order for it to work. Try that.
Jul 10, 2011 | E-Machines eMachines Desktop PC
My IBM ThinkVision monitor flickers the correct display then blacks out. The light goes green a moment, then goes amber with the blackout. I think it may be stuck in the Energy Star/Power Saver mode. Is...
skeltonh, Have you connected your L170 to a different "known-good" PC that has ALL power-save and screen saver modes disabled? Have you connected an old monitor to your PC to see if it will act same way as the L170? 12fixlouie
Jul 31, 2010 | IBM ThinkVision L170 17" LCD Monitor
Ibm thinkvision monitor is stuck in power saving mode. how do i get it out of it?
I would try it on other PC first to narrow down the problem.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 10, 2010 | IBM ThinkVision L170 17" LCD Monitor
Dell Monitor is stuck in power save mode. tried
Hmmm...Stuck in power save. I guess when you push the power button, the monitor says power save, then blanks to power save, no matter if the Computer is on or not.
This means the monitor does not see any signal from the computer. I would suspect the computer first. Try a different monitor (borrow one).
If the size of the monitor picture is too high and the monitor is an older LCD, you may have set the image size too high (1280x1024 will not work with this monitor and it will do this very thing).
A broken or damaged connector cable to the monitor can also cause this. Was the monitor unplugged from the computer just before this problem?
Mar 30, 2010 | Dell E173FP 17" LCD Monitor
LG Flatron W2252TQ Monitor stuck in digital power saving mode
Mike sounds like the little bard in this monitor where the digital and analog connects to is in malfuction and can be purchased for $30 bucks on ebay. You tryed about everything I had on my list is why I come to this conclusion replacing this board will make the monitor work again if I where you I would investigate that.
thanks I hope this was very Helpful for you!
Dec 13, 2009 | LG W2252TQ Monitor
My Dell monitor is stuck in Power Save Mode. Any
The monitor is not receiving signal from the computer. Verify the computer is on and the monitor input is set to the correct mode or auto. Try another monitor if possible.
Aug 10, 2009 | Computers & Internet
How do we turn off the POWER SAVING MODE on the monitor screen?
Try going into your Start Menu then going into your control panel...then clicking on your "power options"....then switching the options to 'always on'..if this does not work..(as it seems you may not be seeing this because the monitor is in power saving mode) try fiddling with the setup option on your monitor and find a possible powersaving mode enabled function and disable it. every monitor is different so I couldn't really help you here...if this doesn't yield results try another monitor to see if it's the monitor having the problems or the computers video card...the video card could very well be the culprit...
Apr 08, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Monitor stuck in "power saving mode"
just press the fn + F5 buttons and screen will appear
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
Computers & Internet Logo
383 people viewed this question
David Payne
David Payne
