Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony tv kv-34hs420 switch it self of.
Tv switchs it self of for about the first hour then when its warmed it works fine if you think its the picture tube its not worth fixing 3 years old.
  • Sony Master
  • 4,806 Answers
Definateley a dry joint if it has to warm up for an hour before it will work properly. If you have no soldering experience at all, then locating the problem will be hard, it may not be worth the time and effort unless you know a friend who can solder and locate any dry joints
regards
Posted on Nov 20, 2008
  • 685 Answers
The problem is your picture tube is going out on it thats why you have to wait for it to warm up befor it will play right.
  • 2,326 Answers
I would not say the picture tube is failing on your TV but there might be dry or cold solder joints in the circuitry and that is why it works when warm.
This repair is not a DIY if you do not have any previous electronics or soldering experience.
SONY TV. STANBY TIMER FLASHING
Hi Frank,
Please let me know if it has a pattern of blinks (separated by a pause) or it will flash an exact number of times. Your unit (KV-34HS420) has a built in self diagnostic software that will indicate the probable caused of the fault by flashing of the LED at the front panel.
Jdvillanueva
Nov 30, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My KV-34HS420 periodically displays an orange screen, then shuts down. The red light on the front flashes 7 times. The weird thing is that this problem occurs during the day, but generally not late at...
hi,
check ur tv for any dry soldering of component leads in the power supply and horizontal output side. also replace the electrolytic capacitor in the B+ supply rail.
u have to check the picture tube base board also for any dry soldering of components, if so the first mentioned complaint ( orange screen) will erase.
ok
Dec 22, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My 34" Sony WEGA has lost its color.
Unplug,replug the tv an hour later.See what happen.U do this to reset all setting back to factory setting.
Feb 23, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron
check the heater as your tv is ON, there must be a yellow light at the rear of the CRT tube. If the heater is ok then check the IC jungle side. resoldering the leads sometimes will solve. If not refer to your local Tech.
Jul 31, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega trinitron KV-34HS420
did a quick google got this:
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/?page=6
blinking is the self diagnosis working.
Aug 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Random Turn-Off on KV-34HS420
Hello there,
7 times blinks shows that Horizontal Deflection Circuit doesn't work properly.
I think, its not big fault and can be resolve in low cost at nearest Sony repair shop.
Feb 18, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Problem:
HEY MASH-1ST ANY MAGNETS/SPEAKES OR MOTORS NEAR SET CAN CAUSE A CHANGE IN THE PIX TUBES PURITY FIELD WHICH IS WHAT YOU SAW. MAKE SURE ANYTHING LIKE THAT IS NOT PRESENT, THEN IF SET KEEPS ACTING UP YOU'LL NEED A DEGAUSSING CIRCUIT REPAIR, BEST DONE BY A QUALIFIED TV TECH.JOE TV
Oct 31, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
18 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
