Question about Sony KP-46WT510 46" Rear Projection HDTV
My TV set, an 2004 Sony Model KP- WT510 Rear Projection is having problems with "Convergence" alignment; everything shows double or triple images and picture is totally distorted; I tried to align the convergence by following the user's Maual instructions to no avail, nothing seems to work.. Thank you for helping me solve this matter..
  • 2 more comments
  • Anvien Nov 20, 2008
    Hello Amji;
    I have already chatted with someone [Ronnie49] from Live Chat Now and although it did not fixed the problem right away I received some advise on how to go about in trying to fix the problem
    and I hope it will work, I was advised to go buy the convergence board and replace the old one
    which is probably defective but I'll need time to do that.
    Thanks a lot6 for trying to be helpfull..
  • Anvien Nov 23, 2008
    I'm working at it, it's going to take me a little time to get the parts and piece the whole thing together,
    so, soon as I resolve this problem; I'll let you all know the results..
    Again, Thanks for all the help,
    Anvien
  • atchisonjd Dec 27, 2008
    I seem to have suffered the same problem with my KP4WT510 this afternoon. The red and blue colors have "unconverged" (if that is a word?). There is also bowing of the picture at both the top and bottom, which exaggerates the convergence issues.
    My question is this...
    Has anyone any estimates on a repair cost for a technician to fix the problem at my house? I would not feel comfortable removing the boards myself.
    I have to decide whether it is cheaper to replace my 2004 set with a new model or repair.
    Thanks for your help
  • luroesor Dec 30, 2008
    necesito foto de la placa de convergencia para saber cual es
  • Sony Master
  • 586 Answers
    Actueally convergence controls by the two IC's called STK.And surely these ic's getting malfunctioning.Therefore you have to change it (Both two IC STK) with the same part number.
   This will surely resolve the issue.
   Thanks
Posted on Nov 20, 2008
  • AMJAD HUSSAIN Nov 21, 2008
    Hello Anvien,
                       Thanks for your comments.In this site we are all here for the  help and provide assistance.And i try my best to give shortes solution in comprehensive way.As far as concern of your product i must feel comfortable when your product do work as it was working earlier.And this is my prime object for all the ppl over here.Actueally i try to cut down your expences too, As repair cost that is why i told you te specific IC's.If you will change the complete board it get much expensive rather then thoses IC's.Anyway the first and last object is the solution which you have now.
                       Thanks you again and take care and plz if possible rate my answer too.
                        Bye.
  • AMJAD HUSSAIN Nov 24, 2008
    Hello Anvien,
    Its isabsolutoely rite that the problem is in Convergence board,But i was only trying to cut down your expences so that i told you about IC STK'S And here I am telling you the specific part No. Along with board number too.The discription is given below.
    Board No. IC80001 and IC80002
    Part No. 8-749-019-08
    Description. IC STK 392-560
    Now with the help of this you can check it by yourself.
    Thanks.
    President:
  • 2,992 Answers
The convergence output integrated circuits aren't doing their job. These are mounted on a heat sink on the circuit board, but they still get hot enough that sometimes the solder connections to them can break. Resoldering the connections would fix that problem.
It's also possible that the convergence circuit is not getting power, usually be due to failure of one of the outputs, which can cause protective fuses or resistors to blow. This would be harder to repair yourself because it involves determining what parts need to be replaced.
It would probably be worth getting a technician to look at the set and give an estimate for the repair.
I have a Sony projection TV KP-53HS10. From one
It is most likely the convergence board. Rear projection TVs use three lights to display the image. The image is aligned via the convergence circuit. After many many hours of use the capacitors and resistors on the board lose their tolerances. It is very expensive to repair if you take into account the price for a new TV and the quality of the image you will be getting if you do have it repaired.
Mar 01, 2011 | Sony KP-53HS10 TV
Seeing triple images of everything
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignmenents,have colors shadows or 3D pictures look alike?The tv convergence board have dead 2 STK Convergence ICS and some or all of it resistors too.These parts on the convergence board must be replaced to fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 03, 2011 | Sony KP-57WS500 57" Rear Projection...
Sony KP 51 HW 40 - in left half of screen picture has double images, right half of screen picture is normal.
This problems very common on DLP Tvs.This problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board is dead.Require to be replaced on the tv convergence board 2 STK convergence ICS and some or all it resistors to solved the tv convergence board problems,to solved tv convergence picture problems.The shop,will cost about $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-51HW40 51" Rear Projection...
Hi, I have a Sony KP-57WS510 57 in. Rear
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 25, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
I have a big screen samsung it plays red and green and the imaged are doubled looks like 3d any ideas
Your question shows its Samsung rear projection TV that has 3 tubes to project picture.
Symptom shows TV got problem in convergence board that will be replaced.
Model number or TV would help me to provide you more info.
Thanks.
Jan 15, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Double image and colour
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
Getting "red" double image
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Double image picture
Your set probably originally had cold solder joints on convergence ic's. After this occurs and alignment jumps in and out a few times chips can fail and need replaced. The amps for convergence are mounted on large metalic heatsinks and sometimes protection fuses open upon their failure. Soldering/ desoldering equip. and test equip. are required to perform this repair and most shops charge between 200.00 and 400.00 to do this. Hope I've helped.
May 24, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
102 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
