Question about HP Office Equipment & Supplies
Light not indicating printer is on-have checked connections
  • grammaturkey Nov 20, 2008
    cant perform -not qualified-printer ishp deskjet 5900-please help-not very technical-grammaturkey
    not working -will take it in -grammaturkey
    Sergeant:
  • 237 Answers
1) Do the above.
2) Make sure you have connected ALL the cables, power adapter to the wall outlet, and the cable from the computer to the printer. You cannot misplug these because they all have different ports/ends. Check for power light indicator. Are there any noise when you power on the printer? If you do, try to feed the paper into the printer and do a sample print. (Also, make sure you have print cartridges...BIG deal! You will not be printing either way if you have power or not wi/o these, lol) If it prints, you will know the light is misinforming you (or lack thereof in this case).
Posted on Nov 20, 2008
  • HP Master
  • 1,879 Answers
Try to feed a paper to see if it's only the light that is busted or the whole unit.
Service is required if it's dead.
    Scholar:
  • 130 Answers
Usining an multimeter, if you are qualified to use one, chech the output from the printer end of the line cord with the line cord plugged in. If there is 120ac there the next step is to check the power supply. The cover would have to be removed. Can you do this? If not take to the shop.
Trying to get an canon mx450 wireless printer to print. I may have pushed reset. I can get printer to say connected and computer to read green light,
Offering some ideas here: You have paper in it, all the doors are closed all the way and if laser printer, the cartridge is in all the way in. Still for some reason it may be off line. I confess I haven't used Microsoft windows for some time but can you go to printers from control panel and try a test page. Check the program you print from go to File--Print and see if the printer shown is the one that you are trying to print to (sometimes someone in office switches it), or printer is shown in print dialogue window when you hold control and press the P key.
Jul 08, 2016 | Canon Office Equipment & Supplies
Tip
General Printer Troubleshooting
Printer does not have power indicator<br />First, make sure that the printer is on. When a printer is on it should have some light (usually green) indicating it's receiving power and is on.<br />If you do not have any indicator light make sure the printer is connected to a working power outlet by verifying each end of the power cable. Next, press the printer power button.<br />If after following the above steps your printer still cannot get a power status indicator it's likely you're encountering a serious printer issue and we suggest contacting the printer manufacturer for additional steps and instructions on repair or replacement.<br /><br />Cables not connected properly<br />Your printer should have two cables connected to it. The power cable and the data cable, the power cable should have already been verified as being connected if your printer has a power indicator light as mentioned above. Make sure the data cable (parallel cable or USB cable) is also connected from the printer to the computer.<br /><br />Printer error (orange or blinking light)<br />After your printer has completed its initial startup you should have a solid green light. If the light indicator is blinking or orange often this is an indication of a printer error. For example, this could indicate a paper jam, issue with the ink or toner cartridge, or other serious error.<br />Because there is no standard to what a blinking light or orange light means if you're getting either of these we suggest referring to the printer documentation for troubleshooting steps or methods of determining what the status indicator is reporting.<br /><br />No paper or paper jam<br />Without paper your printer will not be able to print. Make sure you have paper in the paper loaded into the printer paper cartridge or tray. Next, verify that no printer paper is jammed or partially fed into the printer. If you have one or more pieces of paper stuck in the printer these will need to be manually removed before the printer will print again.<br /><br />Inkjet printer ink related issues<br />Often when you're encountering an ink related issue you're printer status indicator light (mentioned above) should be flashing. If this is not occurring you may want to skip to the next section. However, if you've recently inserted a new ink cartridge you may want to try the below suggestions.<br /><br /> * Replacing ink cartridges and printer not working.<br /><br />Printer self tests<br />Most printers have a way of printing a test page. This page allows you to determine if the printer is physically working or not. This test is usually accomplished by holding down a series of keys. If you are not sure if your printer has this feature or how to perform it refer to your manual or visit your printer manufacturers web site.<br />In addition to testing the printer using the printer self-test Microsoft Windows users can also perform a software self-test to determine if their computer is able to see the printer and it's able to print. Follow the below steps to perform this test.<br />Microsoft Windows 98, 2000, ME, XP, 2003, and Vista users<br /><br /> 1. Click Start, Settings, and open Control Panel.<br /> 2. Double-click the Printers or Printers and Fax icon.<br /> 3. Right-click on the Printer you wish to test and click Properties. If you do not see your printer listed your printer is not installed.<br /> 4. In the Printers Properties window click the Print Test Page button.<br /> 5. If the printer is able to print a test page, you're printer is installed and setup properly. However, if you're unable to print in other programs it's possible that the program you're attempting to print from has issues.<br /><br />Older versions of Windows with older printers<br />If you are running an older printer and MS-DOS, Windows 3.x, Windows 95, Windows 98, or Windows NT, you can also attempt the below software test.<br /><br />Get to a MS-DOS prompt or Windows command line<br />Get to the root directory - Type: cd\<br />Reroute dir to printer - Type: dir &gt; lpt1<br /><br />The above should take the directory listing and print to the printer. If this does not print, refer to your operating system troubleshooting section. Extra Note: This will not paper feed, therefore press your FF or PP, or manually eject the paper.<br /><br />Printer drivers<br />If your printer does not have any flashing lights and is connected properly it's possible you may be encountering a driver related issue. We suggest visiting our printer driver listing, which links to all major printer manufacturer driver pages and downloading the latest printer drivers for your printer.<br /><br />Parallel (LPT) printers<br />If the printer you're connecting to the computer is an LPT (parallel port) printer we also suggest verifying the below suggestions if your printer is not working.<br />Parallel port in CMOS<br /> 1. Enter the computers CMOS setup.<br /> 2. Once in CMOS verify that your parallel port is enabled or installed.<br /> 3. Next, verify the printer or parallel port mode. This option will often have several different modes. If your parallel port is set to ECP mode, we suggest trying a different mode.<br /><br />Other parallel device<br />If you have a parallel printer with other parallel devices such as a parallel scanner or zip drive, temporarily disconnect these devices to verify they are not causing your issue.
on May 09, 2011 | Office Equipment & Supplies
Yellow light blinking
Typically, printers will blink a yellow light to indicate a communication problem between the printer and the computer.
1. Shut your printer and computer completely down.
2. Check connections to printer
3. Follow connected printer cables to the related computer port.
4. Check connections to computer
5. Turn the computer on and let it boot up
6. Turn your printer on.
Jan 20, 2013 | Office Equipment & Supplies
Is this printer wireless
The Lexmark X3650 printer is not a wireless printer. Lexmark wireless printers have the WiFi light logo/symbol that indicates it is capable of wireless connection.
Check out on the Lexmark website the Lexmark X3650 Features & Specifications.
Feb 01, 2012 | Lexmark X3650 Printer
I can't get my printer to print. It seems to be stuck on Paused.
If your printer is connected via wireless network, please try the following.
1. Check if WiFi light indicator if enable and has signal strength.
2. Check if your computer is connected to your wireles router.
3. Reinstall the printer driver.
If your printer is connected via USB cable, please try the following.
1. Check if the printer and computer is properly connected.
2. (for Windows), Check Device Manager if USB Printing Support is present, (for MAC) Check Apple System Profiler if EPSON MFP 2.0 High Speed is present under USB device tree.
Nov 03, 2011 | Epson Artisan 800 All-In-One InkJet...
Unable to communicate thru WiFi to print
A solid green Wi-Fi light indicates that it is connected to a wireless network. An orange light indicates that it is not connected to a network.
Another way to determine if your printer is connected to your network is to print the wireless network setup page. From the printer operator panel, press the Setup button (wrench icon) > Network Setup > Print Setup Page. Your printer will then print the network settings. Check the SSID, signal strength, or trouble code.
A quick fix to this problem (especially if your printer was working fine before with your wireless network) can be achieved by resetting the printer and/or rebooting the PC.
Oct 20, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
My printer wireless indicator is flashing red and I cannot print
The flashing status of the WiFi light on the printer indicates that it's either trying to connect to a wireless network or it has gotten disconnected from your wireless network.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, check the WiFi light status. Try to print again.
You may also refer to this article: Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 05, 2011 | Lexmark Z2420 Printer
What does it indicates when the wifi light is flashing red in the lexmax z2420
The flashing light indicates that the printer is either trying to connect to a wireless network, a "connection failure" or a communication is not available. This article should give you ways on how to fix wireless connection problems - How to identify a Wireless Communication Problem and Resolution Tips. Hope this helps. Thanks.
Jan 21, 2011 | Lexmark Z2420 Printer
Failed to print in epson lx300+, instal new driver & reconnect all connections always failed to print
if you using parallel port cable, try to check if it fix firmly and pause led indicator not light, be sure that printer indicator ready.
Mar 23, 2010 | Epson LX-300+ II Matrix Printer
Printer Acting strangely - red led appears after 13 seconds.
If the red error light is on by itself this indicates a Fatal Error: Fatal error indicates one of the following: ? HP sensor lever or PE sensor lever does not move smoothly. ? HP/PE sensor is defective. ? CR motor is defective. ? PF motor is defective. ? Main board is defective. ? Printer Housing is not secured with screw on the printer mechanism. You could try reflashing the firmware which sometimes helps to rectify this error.
Jun 05, 2006 | Epson Stylus C20SX InkJet Printer
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
