Question about Toshiba Satellite 1905-S301 Notebook
I need to replace the hard drive in my Toshiba
I just need to know how big of a hard drive this model will handle with the stock BIOS that came with it. I have the adapter to the mainboard and I know it's an enhanced IDE ATA-5. It came with a 40 gig and I would like to get as big a drive as I can and still have the BIOS read it. Thank You!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
The ATA-5 Specification barrier According to the ATA specification, any drive over 7.88GB (8.46 billion Bytes) is supposed to report its "geometry" as 16383/16/63 (C/H/S). Which enables old software to access the first 7.84 to 7.88GB of such a drive, using CHS addressing and the BIOS Int 13h system call. And while a P-CHS over 16383/16/63 can be used to access all the drive capacity-- up to the ATA-5 128GB limit-- that is not the recommended way to do so. Rather, LBA addressing should be used to access those larger capacity drives. (Or at least any partition that goes over the 7.88GB BIOS Int 13h CHS barrier.)
So, LBA uses a 28 bit binary number to specify the sector number on a drive. Thus:
228 = 268435455 Sectors
268435455 Sectors x 512 Bytes/Sector = 137438952960 Bytes
Resulting in the 128GB (137.4 billion Bytes) ATA-5 size limit.
Posted on Nov 22, 2008
Compaq CQ50 wont load
YOU are to be COMMENDED!
Do you know how many do not even post the manufacturer name of the computer, much less the model number?
Plus adding the diagnostic measures you have posted?
Wish more people would use the problem area you have used, and wrote a PAGE! lol!
Do need the model number though, along with the model series number you posted. This way I can look at the BIOS versions.
(Example - CQ50-100CA)
Need to ask.........is CDROM the first boot device in Boot Options?
(BIOS Setup)
Could be of course, but you didn't post it. Makes a BIG difference.
The computer HAS to boot from the CDROM, then.
Post back in a Comment.
Regards,
joecoolvette
Mar 06, 2013 | Computers & Internet
How to unlock toshiba satellite laptop BIOS and HDD
If you are the original owner Toshiba will reset the bios for a fee and it is not cheap, they may include the HDD reset, if not! www.ebay.com type password, or hard drive password. I would check bios password, probably a lot cheaper if you can find the right seller, also check www.download.com some software may be free.
Mar 21, 2012 | Toshiba Satellite L455D-S5976 Notebook
Toshiba Satellite A200-28s battery options besides stock Fujitsu
Any SATA drive will fit up to the size limitations of your motherboard. A 1Gb is about the norm now. WD, Samsung, Hitachi etc all about the same.
A 7200 speed will give you a slightly faster seek and write time or go for an SSD drive. All are compatible if SATA 2.5" format.
Oct 03, 2017 | Computers & Internet
While trying to install PATA 250GB HD (XP Pro) only 130GB recognized. Upgraded BIOS to v1.4 (latest) and assured by Toshiba that this would enable computer to handle 250GB. No such luck. Accessed BIOS...
According to the detailed specs on that model, it came with a 60GB ATA-5 EIDI hard drive. therefore, you can use any ATA compatible (ATA-5, ATA-6 or ATA-100) EIDE/IDE drive that has jumpers enabling you to configure the drive as "Master". Western Digital Blue Scorpio and Seagate Momentus lines both have models that will fit the bill. You can find those drives at your neighborhood BestBuy or Staples pretty easily. I don't know if the A25 BIOS supports 48-bit logical block addressing (LBA), in spite of what toshiba says, If it only supports 24-bit LBA the maximum drive size is 137GB. If it supports 48-bit LBA then you can go as high as you can find drives available; usually 500GB. I suspect that it supports 48-bit LBA because various online vendors list up to 250GB drives for that model. The most important thing about the drive, though, is that it MUST be jumperable as 'master'. A cable select only drive won't work. Both the Western Digital and Seagate EIDE models have jumpers. hope this helps but if you need anything else just ask:)
Jul 31, 2011 | Toshiba Satellite A25-S279 Notebook
I cont intstal win xp in my toshiba U200-148 laptop
you can use another installer coz maybe your installer have some scratches
May 22, 2011 | Computers & Internet
Hello. i have the toshiba satellite a200-28n and would like to replace the harddisks at 5400 to 7200 rpm.the types of disk are two mk2046gsx 200 gb each one.what harddisk can i choose for...
The maximum size hard disk you can install in your Toshiba depends upon the BIOS. The BIOS can support a hard disk up to a certain capacity. Check the specification of your model Toshiba to see the maximum hard drive it can support.
An alternative -
You can use an external USB hard drive and connect it to your Toshiba and not be restricted by the BIOS. You can use USB hard drive 500 Mb to more than 1 Tb.
The other advantage of using an external USB hard drive is you do not need to install Windows, the device drivers and your programs on the new hard drive.
Jun 11, 2010 | Toshiba Satellite A135-S2386 Notebook...
Hard drive replacement
I found the book. It was in the archived models.
Click here to get it.
There has to be a BIOS setup to detect the size of the drive. Its could be escape key f1 or f2. One of these keys should trigger it when the Toshiba screen picks up. I didn't see anything in the book about it.
Jul 26, 2008 | Toshiba Satellite 5105-S501 Notebook
Reset bios password
it's the 'clear cmos' jumper you need to move on the motherboard. If you move that over one pin for a moment, then back, then boot up, your p/word will be cleared.
Jul 24, 2008 | Computers & Internet
HITACHI HARD DRIVE LOCKED
Hello Oldnovii
This Toshiba notebook has both a BIOS and hard drive lock on it. The client has already paid $ 25 to the Toshiba depot to have the BIOS lock removed now they want $ 100 to remove the hard drive lock. The hard drive lock cannot be removed by trying to bypass it using a boot cd or disabling the hard drive boot option in the BIOS. Any help will be appreciated since my client has now had the notebook for 2 weeks and cannot use it. Thanks
Apr 07, 2008 | Computers & Internet
I need to replace my hard disk notebook with a bigger capacity hdd
Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
Feb 18, 2008 | Toshiba Satellite A10 Notebook
Toshiba Satellite 1905-S301 Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
