Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
BLACK VERTICLE LINE IN FAXES SENT, NOT WHEN RECEIVED?
The recipients of my faxes get a black verticle line from top to bottom. When I receive a fax there are no problems. What needs to be cleaned in order to remove this verticle line when faxes are sent. Thank you in advance.
    Problem Solver:
  • 11 Answers
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Posted on Nov 20, 2008
How can i Troubleshooting Fax Issues on my hp officejet 4650?
If you get issues like Faxes can be sent but not received, Faxes can be received but not sent error on your Printer then follow the given troubleshooting steps.
Solution to Faxes can be sent but not received
    ·Initially, you have to check any of the telephone line services are enabled. There are,
    1.Voice Mail
    2.Call Waiting
    3.Billing Tone
    4.Privacy Block
    5.Security Screen
    6.Anonymous Call Rejection
    7.Privacy Manager
    ·These may block your incoming faxes. So disable the above features.
    ·If you are using Automatic fax reception option on your fax recipient, then check whether the Automatic Answering feature is enabled or not, if it enables means Auto Answer green LED should be on.
    ·Check the Ring to Answer value.
    ·If the value set as answering machine that causes the issue on fax reception. Then change the value to Fax or FaxTel
    ·Now, you can receive the incoming faxes.
    Solution to Faxes can be received but not sent
      ·Check whether the dialed number is correct or not. Every one of the digits required to make a telephone call from a similar line must be dialed.
      ·On the off chance that the Speed Dial has been used for dialing or the fax has been sent from your PC, print the page to be faxed and dial the number physically on the HP Fax front board.
      ·Check whether the Tone Dialing is set on you HP Fax product.
      ·In the event that faxes are sent effectively from the HP Fax front board, but, it's fail when sent from the PC, test the communication between the HP Officejet 4650 printer and your PC by tapping the Status button in the HP Director application, or attempting to print some record.
      ·If the printing fails to send the fax, then check whether all cables (from system to HP Officejet 4650 Printer) are connected properly, if it's not then connect it properly.
      ·Now restart it. On the off chance that communication still can't be set up, Call Printer customer service team via Toll-Free: +1-800-836-3987 to resolve your HP Officejet 4650 fax issues.
Jun 27, 2017 | HP Office Equipment & Supplies
How do you find fax log for sent faxes on Dell 962 All-in-One
Only faxes sent and received by Fax Console can be seen by Fax Console. View the Status of a Fax Using Fax Console or Fax Service Management
  1. Click Start All Programs (or Programs) Accessories Communications Fax.
  2. Click Fax Console or Fax Management Services.
  3. The following folders appear:
    • Incoming - faxes currently being received
    • Inbox - faxes that have been received
    • Outbox - faxes scheduled to be sent
    • Sent Items - faxes successfully sent
  4. Click the folder of your choice.
  5. Click the fax in the right pane for which you want to view the status, and then click Preferences or Properties.
  6. Click the General tab and view the Status line.
  7. Click Close when you are finished
Mar 05, 2011 | Dell 962 Photo All-In-One InkJet Printer
Heavy black line on sent faxes
You have a defective Scanner Block. EXPENSIVE
Apr 20, 2010 | Brother IntelliFAX 4100 Laser Fax
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
Our faxes are being received with a large/thick
Look on the glass where the scanner is and sometimes a lot of White out gets stuck on the glass, clean with windex and dry good.
If it's a lazer fax, look on the rollers for toner build up around the fuser section. Clean with Alcohol.
Oct 16, 2009 | Office Equipment & Supplies
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Problem with the fax
Introduction Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting. Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Visit the HP Support and Drivers Home page .
    2. Select Download drivers and software .
    3. Type in your model number (HP PSC 2210xi for example).
    4. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    5. On the software download page, select your Windows version.
    6. Locate and select the firmware update.
    7. Follow the directions to download and install the update.
  4. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072).
  5. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
  6. If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or you're not sure of the problem section below .
Oct 24, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fix my fax
Oct 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fix the fax
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
386 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
