Question about Canon NP 6050 Copier
Jamming canon 795
Back in June 07 you wrote
Need a copy of an service manual for a Canon PC-795 printer. My problem is a paper jam locate around the middle section of printer. Have look and look and there's no sign of any paper jam anywhere. My display panel has an blinking light and a squggle symbol that won't go away.
Please help, any assistance will be appreciate.
Did you find an answer, Im having the same problem
Carol
  • Anonymous Feb 13, 2009
    gfhhhfggfhgfh
  • Carol
    Carol May 11, 2010
    You posted the 795 question in the NP6050 section. If your 795 is anything like the Canon NP6050 copier, I would check two places:
    - - Open the top part & Roll open section 1. On the left of the tray is a green handle (right near the "Don't touch me Yellow HOT area). Pull and look in there.
    - - Also, while section 1 is open, squat down and look way inside the hollow section of the copier for a small piece of stray crumpled paper in the back. If you do see something in there, might I suggest inside out tape stuck onto a yardstick. There seems to be no way to get a hand in there.
    If the 795 is not like the NP6050, then I know nothing about it, sorry.
    Problem Solver:
Check the sensors(photointerrupter) & toggle hanging up
Posted on Feb 28, 2009
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
I have a PC-795 the paper feed doesn't take the paper completely through the copier. I also have a finger screw that has come out and I can't find where it goes.
throw the finger screw away. packing for the mirrors. look at the exp lamp are the ends black. if so change the ex lamp. causes jam at regi. otherwise change the feed clutch
Nov 10, 2010 | Canon PC-795 Copier
My Canon MP140 has a paper jam. How to open and remove paper?
Click here. This will take you to the Canon support page for your MP140 printer. Click on the 'Support and Service' tab.
Where it says ask a question type in 'paper jam'.
Next click on the required link, which should give you detailed instructions or a link to help you with your paper jam.
If this helps, click YES below.
Jun 30, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Alarm - paper jam slide platen left - but no jam - won't copy
the paper jam is more than likely in the fuser assembly. unfortunately you will need a service tech to come out and fix that issue.
May 27, 2009 | Canon Office Equipment & Supplies
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
No paper jam and no copies
check the fixing ***'y
Aug 05, 2008 | Canon PC-795 Copier
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
PC-795 Shuts Off Mid Copy
clean big rubber paper feed roller above paper tray with a microfibercloth moistened with rubbing alcohol.
open copier look in lower section under the toner cartridge you will see a black foam roller wipe it off also and then try to use.
Jan 17, 2008 | Canon PC-795 Copier
Canon PC-795
The blinking light with the squiggle symbol is the display for a paper jam. Not sure a service manual will help in this situation other than to be a guide as to where the paper sensors are located. There are usually 3 or 4 paper sensors located in Canon PC copiers. The first sensor will be located between the paper pick up assy and the vertical rollers*(*which are located behind the door on the right hand side used for clearing jams). The second sensor is located under the toner cartridge just before the registration rollers. The third sensor (if present)is located at the entrance of the fuser assy (some models of Canon copiers have omitted this sensor)The last sensor is located at the exit of the fuser assy. I would suggest that you remove the cassette, verify that a piece of paper has not been partially fed or ripped in the pick up assy. With cassette out of machine, open right hand door & verify that there is no jam and check that the flag or arm of the sensor moves freely. Remove the cartridge from machine and again verify there is no jam and the registration sensor arm moves freely. If there is a sensor in front of the fuser assy, verify that it also moves freely. Finally, check for a jam and sensor movement at the exit/fuser. After checking all sensors, unplug the machine and plug back in. (Do this without the cassette & cartridge installed but with all the covers closed) This should give you an install cartridge & cassette message. Install cartridge first. This should give you the install cassette message. Install cassette. If you still get a jam signal when plugging the machine in without the cartridge or cassette, the most likely cause is a blown sensor.(rare, but I have seen it.)If this happens you would then need the service manual to disassemble & repair. I'll keep an eye out for your reply! Good Luck!!!
Jun 06, 2007 | Canon PC-795 Copier
Canon NP 6050 Copier Logo
95 people viewed this question
old marine
old marine
