Question about Carrier 38CKC042 Air Conditioner
Error code air con is bliking light ,so we press the check code,is appere 11 and 97 .it is what mean? How to solve this problem?
    Problem Solver:
  • 5 Answers
On your paper work and or on the door of the A/C unit it should tell you what the code is to fix the problem
Posted on Jan 17, 2009
Panasonic Econavi Air Con nanoe-g timer light is blinking - no power on air con. How do I reset? Have urned power off and taken batteries out and no good.
This is telling you there is an error which you will have to find by putting the remote control into service mode. Hold the check button on the remote for about 5 seconds and the display will change to --. Then press the timer up or down buttons to scroll through the error codes. When the indoor unit beeps quickly for about 4 seconds, you have found your error code and can narrow down your search for the fault.
May 31, 2017 | Panasonic Heating & Cooling
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
How to initialize SHARP 5127 after Code error H2-00 appers
Hi Ambroise,
The error H2-00 means there's a problem with your thermostarts/fusing unit.You need to check them for they may be blown.Replace the fuser if damaged.To reset the code,push P*C* then 14 and then press on the start button[the one you use for copies making].The code is reset.If not,then you need to replace the fuser.
Hope this helps.Thanks!
Please rate this answer.
Nov 17, 2011 | Office Equipment & Supplies
Air Conditioning 'econ' light on all the time
it means there some problem with a/c , low freon , bad switches etc.
Apr 16, 2010 | 2002 Audi A4
Air Con lights flashing!! Help!!!!!
  1. Start the van.
  2. Slide the temperature lever all the way to the left (full cold).
  3. Turn the Mode Control to ‘panel’ (the one that sends air to your face only).
  4. Turn the ‘blower switch’ to all the way to full.
  5. Now go to the leftmost three buttons. Press and hold the top one (rear wiper on constant) and the bottom one (rear wiper washer fluid) until the lights come on solid then begin to flash, and then you can let go.
  6. The AC will now calibrate. You will feel the air blow out of all the different zones at different intervals and see lights come on and go off. Then after a minute or two the top button you pressed will be slowly flashing. This means it has been completed.
  7. Press the last flashing button and you are done.
Jul 24, 2009 | 1996 Chrysler Town & Country
Irc2105
There is no such error 'E215-0000' in ar 5320, for H4 use "#, Interrupt, C, interrupt. Display goes off, Enter 14, Press Print key.
Apr 08, 2009 | Sharp AR-5320 Black and White Copier
How do i resolve error code e007 on canon copier ir2016?
Dear sir; you may try to reset just turn power off and back on, if doesn't work then have go to simulation procedure;
1, press "p" "*" "clear" "*"
2, enter 14 press start
Just try it and let me know, see how does it work.
HAVE A HAPPY HOLIDAY !!!
Dec 18, 2008 | Sharp AR-M350N Copier
Sony Wega wont go on
Hii....
When the " SONY Bliking Codes " generated the circuits self diagnostic to trigger the pulse because some error accure....5 times blinking mean there's something wrong whit RGB level,the level not balance after 2 second due at first time the tv on...the protection circuit will send the error report,the tv will have no picture or sound....you will need to check at M board there's much things you have to do...
Thanks
[Vrya]
Mar 21, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Carrier 38CKC042 Air Conditioner Logo
183 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
