Question about NAD C320 2-Channel Amplifier
Power steering making a ''groaning'' noise
My steering is making a loud groaning noise in the cold mornings. Do I need more PS fluid? Where would I find the fill cap? I looked in my owners manual and it does not show a fill place? Is this what I need? Thanks
2001 C320
  • sdradsek Dec 28, 2008
    I have the same issue. It's actually been going on for a year - get's worse in the COLD. Any help?
    Scholar:
  • 140 Answers
Check your PS fluid. It is stated in your owners manual how to check this fluid. Remember to also check your PS fluid while the car is hot.
If your levels are ok (while running hot) (15-20 minutes of running or idle) then you are prob going to need a new pump within a few months.
Good luck.
Posted on Jan 23, 2009
Why does my 2004 Buick rendezvous make lots groaning sound when making hard right turns slowly
Without hearing the noise it is really hard to say. Two things I would check are the power steering/fluid level and wheel bearing condition to start with
Oct 18, 2015 | Buick Cars & Trucks
2002 Oldsmobile Alero makes loud noises when turning
more than likely it is just low on power steering fluid. system might have air in it now. so after fill power steering unit to proper level driver the car and check fluid level again. and add more if needed . I believe car should have motor running for when checking fluid, same as transmission.
Aug 22, 2012 | 2002 Oldsmobile Alero
Hi. I own a 2004 Buick Rendezvous and I must say, it's the best car I've ever owned. Recently, like within the last 2 months I've had a groaning noise with every left turn. My husband filled...
he filled the PS fluid? it was low? If so it has a leak somewhere, usually the high pressure line. the rattle could be anything, have the front end and steering linkage checked. tie rods, sway bar links, ect.
Aug 03, 2011 | 2004 Buick Rendezvous
There is a noise coming from the right-front wheel area during a left turn. It almost sounds like a tire-rub on the inner wheel-well cover, but it also makes this same noise when stationary while turning...
I had this same problem and the dealer could not reproduce the noise when I would take it in to get looked at. (during the day when the temperature was warm) So I decided to leave it over night and they test drove it in the morning when the temperature was cold and they heard the noise. It ended up bing the steering rack.
Nov 02, 2010 | 2001 Nissan Altima
Car groans when turning corners
You need to describe the problem better. Does it groan only when moving and turning, or will it make the same noise just sitting there turning the steering wheel. If it only makes noise when moving, that rules out a ps problem, the ps doesnt know if you are moving or not. Does it make different noise if you are going to the right or left, same noise, different? I dont know about the reservoir, some of them have filters, but I dont know if Buick does or not. If it was, it would cause a whine, not a groan.
Dec 19, 2009 | 1999 Buick Park Avenue
Power steering leak making loud buzzing sound more loud when turning
The power steering leak is creating bubbles in your power steering pump which gets strained more when turning, which causes it to be louder when turning. If you know where your leak is, then fix that, then try to bleed your ps system by filling up with the cap off the resevoir and turning the steering wheel max left to max left with trans fluid. if the noise is still there then your ps pump needs to be replaced along with the ps vsv located on the side of the pump.
Oct 08, 2009 | 1991 Lexus LS 400
Loud whirring noise at start-up
The first thing to check would be to make sure the power steering reservoir is not running near empty, locate the filler cap for the power steering pump it should be marked and then add the appropriate amount making sure you don't over fill, that may make the sound go away if not we must move on to the next possibility, by the way if the noise gets louder when you turn the steering wheel it is most likely the power steering pump or fluid level is low.
Jul 14, 2009 | 1998 Mitsubishi Galant
1999 Lexus ES300 Steering wheel make groaning noise
Hi
If the groaning sound is still happening, you are probably low on power steering fluid. I suggest starting there. Remove the cap and check the dipstick attached to the cap. The reason the sound would go away at high speeds is that you don't turn the wheel as sharply at higher speeds so the pump is not trying to pump air ( that's the groaning sound ).
If you are low on PS fluid, fill it but check for leaks for a while. Look under the car in the morning for fluid. If you spot a leak, take it back to whomever replaced the hose and have them fix it.
As far as the engine light goes, first make sure the gas cap is on properly, meaning all the way. Turn it till you hear it click several times. If that is all it was, the light should go off after 20-30 miles or so. If it stays on, try changing the gas cap. That is probably one of the cheapest routes to go.
Good luck
Apr 12, 2009 | 1999 Lexus ES 300
Loud groaning noise while turning left
Hi
The groaning noise is the power steer pump operating under duress. I would suggest having the front suspension checked for any seized or failing ball joints or control arm problems. Most suspension guys will give the undercarriage a look over for you for free to check for any failing/unsafe parts. The engine belt driving the power steer pump should also be checked in case it needs adjustment.
regards
robotek
Dec 06, 2008 | 2002 Buick Regal
NAD C320 2-Channel Amplifier Logo
152 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
