Question about Dell Motherboard Dimension 4100 Intel 815 DP/N: 031REP 31REP 31REP
Memory upgrade i have a dell i am trying to upgrade the system to 1GB but it is not seeing the 2x512Mb sticks that i have installed whatcould be the problem.
    Genius:
  • 1,066 Answers
I concur with crazeetrayn
Posted on Mar 07, 2009
  • Matthew Spark
    Matthew Spark Mar 07, 2009
    i concur with crazeetrayne, you can only install 512 max ram, by using 2x256 sticks
  • 837 Answers
Dell dimension 4100's only support a maximum of 512MB ram.
2 - 256MB PC133 SDRAM modules - 1 in each slot
Posted on Nov 20, 2008
How can we solve the problems of Ram code error 2000-0123
Sub out the ram memory one at a time if possible and see if there are any changes, if you have the one stick remove and reseat back in position, if no change, replace ram and upgrade to 1GB, "2X512MB" one for each slot.
Apr 21, 2012 | Dell Optiplex GX280 Desktop Computer -...
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
Want to upgrade memory to 2 GB. Desktop will not post up with 2x1GB cards. Every 2-3 seconds it makes a sound/tone. The fans would turn on but there is no signal to the monitor. However, it will post up...
There is no reset just because you added memory.
If you have 2- 1GB sticks, try both , one at a time.
Your system spec's and manual tell nothing which dimm banks are suppose to be used , and if you can install 2-1GB sticks,
all it says is it can handle 2GB.
Now it says 512MB, sticks, this could mean you can only use 4-512MB sticks to get too 2GB,.
Now it does not tell which dimms are used if you have 2-1GB sticks,
You have 4 slots, the first two and the second two, most times, you either use the second bank of each pair, or the first slot of each pair,
but as I said, your system does not say.
So you can try both ways and see if one of them work.
Sorry I can't be of more help,but you system has a poor manual
on memory placement.
Feb 14, 2010 | E-Machines T3302 PC Desktop
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Feb 22, 2009 | Dell Dimension 3100 PC Desktop
Dell 8400 new memory
If you are using Windows XP, go into your control panel, double click System (from classic view), and look towards the bottom where it says "Processor x.xx GHz, x.xx GB of RAM" and make sure your 2.00 GB of RAM is recognized by Windows. Next I would make sure you are using 400- or 533-MHz DDR2 unbuffered SDRAM. If you are, try removing one of the two modules and see if the computer runs smoothly. If it does, I would install a different brand of memory.
Dec 31, 2008 | Dell Dimension 8400 PC Desktop
I need to upgrade the video and Memory on my SX280 Dell lunchbox
According to nVidia the 8500 is a PCI expressX16 card and designed for hight speed DDR2 and GDDR3 memory.
I don't think you'll have any problem adding 2X 1GB memory affecting the power supply but check the tech specs on the card for fit in your case.
Let me know if this helps
Dec 31, 2008 | Dell Optiplex SX280N (SX280NMIN) PC...
Error message after installing memory ram upgrade.....
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
Dec 20, 2008 | Dell Inspiron E1505 Notebook
Dell Dimension E510 memory upgrade
Please check the type of RAM you are using.
You must return it to BestBuy and try using a Dell store.
Call Dell Accessories sale and they will be able to give to better options and it wud work too.
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
88 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
