Question about iLO 3200 32 in. LCD Television
Screen flashing 4 different colors on ilo 42 inch flat screen
My scren flashes white green red and blue no reception what could this problem be,not a plasma ilo lct42ha36
SOURCE: ilo LCT42HA36 remote control
Ilo is apparently made by a few different manufacturers for Wal-Mart. Try Emerson, Funai, Akai or Tatung universal remote codes. I have read that the Emerson works most frequently.
Posted on Jul 01, 2007
djnick989
  • 1067 Answers
SOURCE: Ilo 42" Wide Screen LCD TV...Picture Malfunction
From some of the forum threads I've read about this, it seems like there were early issues due to bad firmware, but they have all be resolved with the recent updates. It also appears to be very easy to replace the hard drive. Just swap it out, format from the menu and you are done.
u will neeed to get it updated
Posted on Jan 25, 2008
skotkolr
  • 558 Answers
SOURCE: ILO 42 IN PLASMA
most likely several capacitors are blown on a power vga board you could have a tech come out to see if he can replace them.
Posted on May 11, 2008
  • 12 Answers
SOURCE: 42 inch ilo tv black picture sound only
If the fuse burned out the the tv would not turn on at all. When the tv is on is the back light still on? If its not its probably the back light that needs changing. If its on then its one of the circuit boards.
Posted on Jun 21, 2009
dsacco86
  • 1077 Answers
SOURCE: I have 42 in ilo plasma tv. I can turn tv on but
Most likely the TV has a Mother board related issue. Your TV is just like a computer. When it freezes up, nothing responds and you have to pull the plug to turn it off.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part or replace the whole circuit board. The Service Manual will give you circuit diagrams, test points, and part# lists.Service manual cost about under $20. Most cases the new part cost less than $15. New circiut board, depending on type, may cost about $125.
I hope I shed some light on the subject for you.
Posted on Jul 08, 2009
Jan 25, 2008 | iLO 3200 32 in. LCD Television
TV just flashes different colors I have a sharp aquos 4K 55 inch I bought like 3 month ago and keep flashing color blue, red ,white , green what should I do ??
I would at this point send it back. It has a year warranty. The problem is most likely the inverter but like I said, return it for a replacement.
Jul 10, 2016 | Sharp Televison & Video
Why did it work before installation, now flashes numerous different colors?
Before installing replacement parts???
I can assume that the t-con board or the video board had terminal connectors or ribbon connectors. What is often overlooked is a misaligned connector or worse, a broken or bent pin. Try examining these connection points. You may have to use a magnifying glass. A defective screen usually goes black or produces broken images and/or color points.
I hope this helps.
May 30, 2015 | Protron PLTV-4250 42 in. LCD Television
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Flashing red,blue, green screen
last week i had an emerson 21 inch with built in dvd.,it was flashing colours.none of the front buttons would work.i unplugged the front buttons and plugged them back in again.set is working fine.ican not remember if i did it with the power on or off.try both.some how the front buttons were locking up the micro.
Nov 24, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Viewsonic N2750w flashing different colors on screen
did you get any answers? I have the same problem.
Jul 06, 2009 | Televison & Video
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
iLO 3200 32 in. LCD Television Logo
90 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
