Problem signature: Problem Event Name: APPCRASH Application Name: Sibelius Student.exe Application Version: 5.1.1.1 Application Timestamp: 4798b285 Fault Module Name: ntdll.dll Fault Module Version: 6.0.6001.18000 Fault Module Timestamp: 4791a7a6 Exception Code: c0000005 Exception Offset: 00043387 OS Version: 6.0.6001.2.1.0.768.3 Locale ID: 2057 Additional Information 1: e755 Additional Information 2: 4bfec05577323d0b4f7273ccda7fc006 Additional Information 3: 1846 Additional Information 4: aa9511996acb90328eea9f26af20e75f Read our privacy statement: http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
iqbal_del
  • 655 Answers
SOURCE: Problem Event Name: BlueScreen
It seems your OS has been currepted and you need to re-install.
Before re-install try the followings:
1. Boot your system in Command Prompt Only
2. Run SCANREG
3. It will list that when your system was booted successfully
4. Select any one of them and make re-boot.
5. It will be fixed
Otherwise you should re-install.
Thanks
iqbal
Posted on Mar 09, 2008
Mesmo
  • 164 Answers
SOURCE: windows explorer has stopped working
Well if it continues to crash then theres a bigger problem
but a way to make it recover if the EXPLORER.EXE crashes is to hit
CTRL+ALT+Del
File
New task
Then type Explorer.exe and it should reload itsself and be back to normal
i also suggest running a scan with Ad Aware 2008 just in case wat u downloaded could by spyware
Posted on Oct 21, 2008
Romy_Dec
  • 56 Answers
SOURCE: WINDOWS EXPLORER HAS STOP WORKING
Hey there
The problem could be because earlier version of nero You can solve your problem from doing the following:
If you are using Nero, you can try upgrading to the latest version (7.7.5.1+)
If you’ve upgraded Nero and still have the problem, you can try renaming the file C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax to NeVideo.ax.bak. You may also need to rename NeVideoHD.ax to NeVideoHD.bak
This will break Nero Showtime, however.
There's another possible solution below of turning off DEP for dllhost, which might not work your windows explorer
Essentially, turning off Data Execution Prevention on dllhost (the COM surrogate or windows explorer) can fix this problem. This solution is detailed below.
Right click on Computer, and choose Properties
Click on Advanced System Settings, and then under Advanced, click Settings
Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and services except those I select”
Click on the Add button, and then browse to C:\Windows\System32\dllhost.exe
Click Open, and then OK.
Enjoy working
Gimme your acknowledge by rating me
thanx
Romy
Posted on Oct 24, 2008
Code Blue
  • 86 Answers
SOURCE: I have downloaded avs video
try cleaner and advanced system care after you uninstall it and then again after you do install it.
Posted on Mar 19, 2009
  • 92 Answers
SOURCE: I ave a clx 3170
I am not sure what software your using to fax through the pc with or if it is software that came with the printer? I would try and uninstall the printer and the software, make sure your using the drivers and software that is correct for the version of windows you are using, double check on the MFG website. Then reinstall the printer and the software driver version to see if this corrects the problem. Hope this helps.
Posted on Sep 12, 2009
MGA BUGO MO !! piste ... KA ! CHE ! pak u
Oct 14, 2013 | Computers & Internet
You could uninstall unzipexpress and install winrar or winzip.
Sep 20, 2013 | Microsoft VISTA Computers & Internet
Problem Event Name: APPCRASH Application Name: SBUpdate.exe Application Version: 1.0.3.4
What software by Speed Bit do you have? DAP? The Speedbit updater failed to respond. Go to Speedbit and reinstall: http://www.speedbit.com/video-downloader-converter/
Jan 16, 2013 | Dell Studio XPS PC Desktop
Http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
Application Name: arma2OA.exe
Dec 02, 2010 | Computers & Internet
Please try disable the Data Execution Prevention(DEP) or add the Yahoo messenger.exe in Data execution protection (DEP) exclusion list. This error is comming because you have enabled DEP. I think it will help you to fix the issue.
Thanks for joining Fixya community...Good Luck
Dec 09, 2009 | Yahoo Messenger
Sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe ...
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
Aug 07, 2009 | Computers & Internet
APPCRASH hpfcopy.exe
Reinstall rather fresh install the system for the better performance in future. and not to face the problem.
Jul 10, 2009 | HP Pavilion dv2000t Notebook
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
