Question about HP Office Equipment & Supplies
Need new power supply box and a new front panel. Where is the nearest hp service center where I can buy these parts and install them myself?
    Genius:
  • 2,120 Answers
I have a Phillips Plasma Tv 42pf532 and suddendly turns off
Check its power supply regulator section. Look for any bulged capacitors. Replace them if any. It will be best to replace the power supply board as card basis, rather than making 'surgery' to it; especially to Plasma TVs. Most of the spare part it have, will be very difficult to get from open electronic spare part market.
Contact the nearest authorised service center for Philips to buy a new board.
May 28, 2012 | Philips 42PF9630A 42 in. Plasma Television
Tv keeps turning off
Check for any loose solder terminals at the power supply regulator board. Resolder all suspected terminals, by applying fresh solder. If it do not help you, replace the board as card basis. Contact the nearest Pansonic authorised service center to buy a new one.
May 28, 2012 | Panasonic TH-42PX75U 42 in. Plasma...
Power blinks twice and OPc blinks five times
The power supply regulator section have some shorted component/s. It might need replacement. Card base replacement will be better. Contact the nearest authorised Sharp service center to buy original power card.
May 12, 2012 | Sharp Televison & Video
Power supply went out (at least I think thats what it is) on my Polaroid FLM-4034B 4-" HD TV, if I buy the new power supply, is it easy to install myself? Will I have to do any soldering? I am not any...
Hi Scott,
Replacing the power supply board is not quite technical, no soldering required. But before an attempt to do so, let stand the unit for 1 hour to drain the main filter electrolytic capacitor. Power supply board is where the power cord directly connected. Pull-out all the cables connected from the existing power supply board and then put in the new board, re-insert the connectors and ensure that it is properly seat-in.
Click this link for the replacement or obtain it from your local Polaroid Service Centers.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Jun 05, 2011 | Polaroid FLM-4034B 40 in. LCD HDTV
Display is very light and you can hardly read what it says.
did you mean the display panel? there are some possibilities concerning with this problem. first, loosen connection. second, not enough power to support the printer check the power supply if it generates exact power to run. third, display panel is defective consult HP support or go to your nearest HP service center.
Jan 04, 2011 | HP Photosmart C5280 Printer
Power supply board where can i get 1
just go to your nearest LG service center to buy a new power supply board. and fix it
Jun 19, 2010 | LG 42LC2D 42 in. LCD HDTV
New 23 inch samsung lcd tv turning on and off by itself?
common problem for Samsung- usually caused by a defective power supply board and yes I have seen this on new machines right out of the box. can call 1-800-samsung or go to samsung.com for nearest service center. should be fully covered under warranty.
Dec 17, 2009 | Televison & Video
How do i separate the top part from the bottom part of my laptop. I want to buy another motherboard, but I'm not sure I can do this stuff myself
I don't think you can, maybe you can separate it but how you sure that when you buy a new motherboard is working. Or maybe you can buy the exact design of motherboard is how you back back in. Even user manuals are not put to know how to disassemble the laptop. Only Certified Technician can do that my friend.
Just bring to your nearest HP Computer Center to let them provide all of it, at least you have warranty whatever problems occur again.
Hope this tip might help you.
Sep 23, 2009 | HP Pavilion dv1000 Notebook
I have a 37 inch Insignia flat screen tv. This morning we were watching tv and all of a sudden the tv went black. We still could hear the movie playing but no visual. We turned the tv off and on and all...
This unit needs to be tested in a service center because it has problems with the operation of the video card. This could be caused by a loss of voltage supplying the video card from the power supply card. Or a failure on the video card itself. You can purchase parts for unit from Best Buy Parts at !-888-237-8289 and get customer service at 1-877-467-8289. You should get an estimate from the service center, That should tell you which parts are bad and then you can proceed from there. If the prices seem too high for parts and labor from the service center, try buying the parts yourself and have them install them for you. You should try to check the prices on the parts , just to make sure you are getting a fair deal.You can do this by getting the part numbers, you should ask the service center to provide the part numbers needed if they need to replace the power supply board or video board and with your model number of television check out the prices and availability at the Best Buy Parts website.Of course if the television is still under warranty send it in for warranty service. Hope this helps you with your problem.
Apr 26, 2009 | Insignia 37" LCD Flat-Panel HDTV
Power supply replacment
You should be able to replace the power supply. It is usually held in place by 4-6 screws. Unplug the cables on the motherboard and drives. Reconnect the new ones and away you go. A generic supply will be fine if it is of the correct physical size. Bring the old one with you when you go to get the new one.
Dan
Mar 18, 2008 | HP Pavilion A520n (DW233A#ABA) PC Desktop
102 people viewed this question
Ben Johnson
