Question about Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2 1200, 1600 MHz FSB, PCI-E 2.0, SATAII, GbE LAN, 8 Ch... Motherboard
Overclocking I have purchased a Gigabyte GA-EP45-DS3L/S3L board, Intel E4600 cpu, and would like to know the proper way to overclock this system. I have 4gb of 800 ram, and running Vista Ultimate. I am new to overclocking and have read that this cpu should be able to run at 3ghz. Thank You
  • rlussenden Nov 23, 2008
    Thank you for your help I was able to bump the cpu to a stable 2.9ghz and temp is staying under 95 deg. F.
    Sergeant:
  • 207 Answers
First a few words of warning. There have been many cases where someone was doin overclocking and have fried their CPU/Motherboard or both. By overclocking you will likely void the warranty on your CPU/Motherboard/ and RAM. By partaking in any of the directions listed below you take your PC's life into your own hands and only YOU are responsible for the outcome. If your comfortable with that read ahead.
Apparantly Gigabyte has made it EASY for you to overclock (Meaning it is LESS likely that you'll void your Motherboards warranty)
OK there are two methods you can try to overclock (O/C) your system
The first is the safest but may not boost your system to the Max stable
Here we go.
1.) Go into your BIOS(Push <Delete> at startup)
Select "MB Intelligent Tweaker"
Goto C.I.A.2 and swith it to enabled
save your settings and reboot (If the system act unstable[Crashes] then enter bios again and disable setting again)
This sets the system up so that when it detects processor intensive tasks it will boost performance a bit to speed things up. (It called dynamic Overclocking which is less risky since its not ON all the time but usually never reaches max performance)
OK here we go on #2 it's more risky but the pay off is usually bigger
2.) Again go to M.I.T
a.)This time we want to adjust "CPU clock ratio up by 1
save and reboot do some things in windows to see if the system is stable. If it is then go back and boost it 1 more, keep going until the system become unstable (Crashes BSOD's etc.....) then go back and reduce to the previous STABLE setting (We now know your Max Multiplier)
b.)Now increase your "Fine CPU clock Ratio" by .5 increments again we are going to increase 1 step at a time until we get an unstability and then back off by 1 increment (If you can't even go up 1 increment then back off the multiplier [step a] by another stage and then repeat step b )
We now know your Max settings for both muliplier(Step a) and FSB(step b) I would recommend running them at one stage below the MAX's but the current settings should run OK for you. It is common for O/C''d systems to run hotter so it would also be advisable to get extra cooling into the case (More fans, a water cooling system or a peltier cooler)
Hope this helps you
Dave
Posted on Nov 20, 2008
  • 781 Answers
You have to go into the BIOS setup
and change the Multiplier and bus speed.
If you do only change one at a time and in small Increments rebooting each time
Does your computer do what you want it to do. If so leave it alone as one bad setting in BIOS can stuff your CPU up
Will not boot
Normally is an incompatibility with CPU. You would need to change the CPU to and older one (compatible) and update the BIOS to last version. That should fix it.
Jan 17, 2012 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
HI, i have the gigabyte MB GA-945P-S3- and i saw in GIGABYTE web site that i can go with C2D E8400 but with overclocking and saw awhile ago that there are another problem with the CPU MP in the bios of it...
Only the Gigabyte GA-945P-S3 revision 3.3 does allow C2D E8400 or C2D E7500.
However the C2D E8400 only by overclocking, which certainly is not recommended.
So the Gigabyte GA-945P-S3 mainboard revision 3.3, should work with the C2D E7500
with BIOS version FFd and FSB setting at 1066 MHz.
Sep 04, 2011 | Gigabyte GA-945P-S3 Motherboard
I am going to assemble a pc my specs are core i7 930 ati radeon hd 5770 4 GB ddr3 ram 500 GB sata hard disk i am confused about the motherboard,which motherboard i should buy for gaming gigabyte...
Both boards would be fine considering the hardware you are installing with it are good for gaming, sometimes,games dont get affected much by boards, they are affected by RAM,VGA and the processing power of your processor.
Very little or minimal effect are felt by differentiating boards. The right question here would be which board would last longer or take more abuse vs the price you have paid for it. For games, specially online ones, such as RPG,MMORPG,etc, are heavy abuser of system resources and hardware.
You might want to add in your list decent cooling systems,may it be AIR cooled or Water cooled. For better efficiency and durability of the parts, secially if you are aiming to overclocking.
Heat renders parts life span almost in half,as I experienced it.
Oct 20, 2010 | Intel Motherboard
Hello..I recently bought GIGABYTE GA-EP45-UD3LR motherboard.I built my system, my hardwares and my os, so it seems it works properly right now.But there is a problem I couldn't fix.Here it is: My...
Dont use Everest, or get an upgrade - Gigabyte has its own version. The problem may be that your board is not on the internal list that Everest uses, so it lists the default one for that maker.
Apr 15, 2010 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
Problem Booting Motherboard After Overclock
hi unplug tour cpu chassis just remove the battery found on motherboard for 5 minutes then put it back inside
Jan 19, 2010 | Gigabyte GA-X48T-DQ6 S775 X48 ATX DDR3...
I have a GA-EP35-DS3L/S3L Motherboard and i want to update the BIOS driver.
Hi go here and insert the motherboard you have, there is a slight difference between the GA-EP35_DS3L and the S3L. Download your link and follow the instructions that come with it.
Click Here
Hope this helps
Sep 25, 2009 | Intel D850MV Motherboard
Overclocking E6300 on GA-8I945GZME-RH
yes you can. but awar of thet instability can appare..
Jan 09, 2009 | Gigabyte GA-8I945GZME-RH Motherboard
Overclock an Intel E6300 on a GA-8I945GZME-RH motherboard
You need to check your BIOS. If you can overclock you will see a selection for CPU and speed in BIOS. If not there then your motherboard does not allow you to overclock your CPU.
Rate this solution.
Jan 09, 2009 | Intel Core 2 Duo E6300 / 1.86 GHz...
Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2 1200, 1600 MHz FSB, PCI-E 2.0, SATAII, GbE LAN, 8 Ch... Motherboard Logo
167 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
