Question about Emerson EWC1903 19 in. TV/VCR Combo
Tv won't turn on.
When pushing the power button on the front of tv, to turn on, hear a split second sound from speakers, Video head (carousel) just moves ever so slightly one direction. Push the power again, same sound, carousel slightly moves opposite direction. Push a vcr tape into it and push the power button at the same time. sound from speakers, carousel takes off at full speed, kicks vcr tape out, then shuts down. All in a matter of 5-10 secs.
Any help would be greatly appreciated. Thanks !!!!
Emerson EWC 1903 19"
4 Suggested Answers
SOURCE: Emerson TV won't stay on
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Posted on Mar 16, 2008
SOURCE: TV code for Emerson EWC 1301 TV/VCR Combo
how do use revmote to program tv vhs thank you11
Posted on Jun 21, 2008
SOURCE: Emerson EWC 1302 Tv/VCR combo shuts down
I've seen problems like this with 2 tv/vcr combo sets before. in my case each time the sensors in the machine think there's a tape jammed, and it shuts down to prevent damage. if tihs is what's going on it should actually say onscreen that it's trying to eject a tape, whether there's one in or not.
WARNING: this fix may get the tv working again, but the vcr will not be usable.
if this is what you're seeing then step one would be to remove the tape (assuming there's one there at all), now turn it back on and see that: THIS DIDN'T FIX ANYTHING! that's where step 2 comes in, you need to probe around a bit, in my case this was very much a trial and error thing, and find which mechanical parts are in the wrong positions. you want everything in the position it should be with a tape ejected. with this done you should be able to turn the tv on without getting the eject message and having the tv turn off.
Posted on Nov 15, 2008
My ps3 won't show on tv but it show that it's playing
Are you saying that it has sound but no video?
Plug only the video plug (yellow) to the TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 07, 2011 | Sony Playstation 3 (PS3) Console
My PS3 will not turn on to its main page! I Push the in button, it "beeps" but when my tv is on it proper input channal there is nothing? It won't turn on with any remote unless they are pluged...
Hello, it sounds like you need to reset your video output.With the power already off,press and hold down the power button till you hear the second beep then let go ,your video should rest about 8 seconds later.
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
Panasonic projection tv model tx 43p950x, there is power loss while I turn on the remote and there is no power when I pushed the button on front of the TV. Before it happen I connect an audio cable on the...
separate the power cords between different outlets but they have to be on different curcuits. if you have a surge protector it could be bad you can try another 1.
Apr 12, 2017 | Panasonic Televison & Video
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
How do i fix the volume because i do not have sound? my tv has no volume/sound. tried turning the tv up and down but still no sound
1 - hi
2 - check the jack for headset
- if you heard any sound with headset = your speakers are burned
3 - if you always use this jack for head set its maybe got problem = when push or pull the headset jack if you hear any sound from speakers your headset socket should change
4 - if you didnt hear any sound from both (speaker and headset) it means your ampilifire should repair
May 23, 2010 | Emerson CR202EM9 TV
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Pic
if you have a SD TV. ( standard display, not HD ) but chose the HD display option on system settings you wont see picture but hear sound. and same goes if you've chosen SD display but own a HD TV. so try to reset your system somehow or take it in for inspection.
Jul 13, 2008 | Sony Playstation 3 (PS3) Console
RCA F36685 wont power on
Probable bad flyback transformer....verify service number
last three digits YX2....Part # is 244247.............................T.
Nov 28, 2007 | RCA F36685 36" TV
Emerson EWC1903 19 in. TV/VCR Combo Logo
42 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
