Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi zdt6252 stops on 'Rinse & Hold' midway thru Wash Cycle consistently...
Hello, We have a Zanussi ZDT6252 Built-In Dish Washer and lately is stops after approx. 5 mins on the 'Rinse & Hold' status. We have to turn off the washer and re-try..although lately it stops on a consistent basis. I have ensured the Filter is clean and also have removed the center basin in the washer and ensured that all is clear there also...however the problem still persists. What do you recommend... Thanks in advance for any advice. Peter.
  • Anonymous Dec 07, 2007
    i have a zanussi ZDT6252 i put it on a wash cycle during the night next morning risr hold was flashing, no cleaning was don.
    i have check the filters both are clean, is their a reset function
The problem here is being caused by Blocked Filters in the Water suppoly In line/pipe. There are two(2) filters in this line, at the water connection point and at the Washer connect point(one at each end). If these filters become blocked, then the result will be a restricted water In-Flow and hence the Rinse & Hold Status. Disconnect the Water-Supply pipe and remove the plastic filters giving them a thorough cleaning before replacing them. All will be rectified by this action. Peter...
Posted on Mar 18, 2007
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwasher power there but wont fill up with water makes a slight buzz sound any ideas please ?? It's a Zanussi zdt6252 by the way..
The slight buzz is coming from the water inlet valve solinoid. It's OK.
But check whether water is getting into the inlet tube of the washer. Check the filter at the rear of the dish washer body wher the inlet tube from your water tap is connected.
Apr 05, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
My Zanussi dishwasher wont run a programme
Hello Paul, The first thing to try is to clean the filters at the rear pipe(s) that connect to the main water supply. It is quite common that when the water-flow is impeded, the programs may stop with flashing lights depending on the rate/amount of blockage.
So, pull out the unit and disconnect the rear pipe and give the in-line filters(s) a good going-over. Please let me know if this does the trick...
Best Regards,
Peter...
Aug 11, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT6252 fills with water when not in use
Sounds like you have a leaking inlet valve. The best option is to replace it with a new one. It does have overfill protection on it but this may not work if its leaking.
Nov 13, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT6252 Levelling
After having the same problem I resorted to sawing off the rear foot, only to then discover that there is a crosspoint screw on the middle at the fron that winds up or down the rear foot.
Nov 03, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
508 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
