Question about LG LDF6810 Built-in Dishwasher
IE input error on LG dishwasher Model LDF6810ST
Brand new dishwasher. 3 out of the 4 times we have run it, we get the water inlet trouble error- but the cycle does not stop and you can hear water flowing. So far the solution has been- stop the cycle, jiggle the hoses, and after 2 or three times, it works. Cannot see any kinks.
Anyway to fix it so we do not get the error at all?
I have read about checking the float- where is that?
Any advice will be appreciated, thanks, Chris
  • 1,543 Answers
Chris;
The float you speak of is located behind the left side panel. (be careful if you remove the panel, the back edge is real sharp,.... I left a pint of blood at one house !) Water enters the dishwasher fill assembly and turns a paddle wheel, which allows the control to count the revolutions, determining the amount of water filling into the dishwasher. The float is inside a chamber in front of (and attached to) that water guide and it has two micro switches at the top of the float chamber. If I recall correctly, the float is only for overfill protection, as the paddle wheel determines water amount. You should check the screen at the water valve to make sure nothing is obstructing inlet valve water flow. Also, make sure you are not using a "flood safe" inlet hose, which are designed to shut off water if a hose breaks (but can cause water supply issues). You may have a bad control board or wiring connection. On a new unit I would suggest calling for warranty service.
Please don't rate this solution, as anything but a FixYa will lower my score.
Thanks, Carl.
Posted on Nov 20, 2008
Why does it stop running after two mins and has an error code of OE?
The OE or Overflow Error code.
The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
Feb 13, 2016 | LG LDF6810ST Stainless Steel Built-in...
Why does my LG ( LD12AT7 )dishwasher still give me an IE error code after I replaced the inlet valve?
When this happened to my 12 year old dishwasher, I take out the filter at the base of washer, and using a cup, drain excess water. Add the cheapest VINEGAR to the base, screw the filter back in. Wait a few hours for the vinegar to do its magic, hey presto! the machine works again. I'm ready to buy another, newer model, but this trick works everytime! Sometimes, I don't even empty all that fluid out, but just add that Vinegar. Hope this solves your problem too. Havagreatday!
Aug 19, 2014 | LG LDF6810ST Stainless Steel Built-in...
Lg dishwasher error code e1
Looks like water input error. It is likely due to lack of adequate inlet water flow the dishwasher turns off. Make sure the kitchen inlet tap is fully open and water pressure is consistent with the recommended water pressure for the dishwasher. You may need to provide the model number if you want more details. Good luck.
Apr 29, 2014 | Dishwashers
The dishwasher begins to start, then it stops, beeps and flashes the letters "IE" on the screen. We have tried every setting and it does the same thing.
Hello
The "IE" error code indicates a problem with the water inlet. The water supply valves are not turned on fully or the inlet hoses are kinked, clogged or frozen. Remove kinks in the hoses and remove clogs with a straightened coat hanger. If this does not resolve the problem, contact a service technician.
Sep 07, 2011 | LG LDF6810ST Stainless Steel Built-in...
IE error on LDF6810ST, it's not the valve or the controller
Try to check water flow sensor that attached to the water intake plastic thin container. It's located from the inner side therefore you won't see it from the first glance. You have to take it apart then find it from the inner bottom side.
Jun 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
What does the trouble code "IE" mean
IE Error = Water Inlet Trouble - Check water inlet and outlet hoses for cracks, kinks, sponyness, and check the water supply.
http://www.yellow-mini.co.za/dishwasherfromhell/
Oct 29, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Error code LE
If you are getting a "water inlet" error "IE" I found out thru trial and error that my inlet valve(s) were messed up. On my particular machine you can put the machine in trouble-shooting mode by pressing the "Spin Speed" and the "Soil Levels" at the same time and press the "Power" button while doing that. Then advance thru all the functions by pressing the "Start button"
1 time; Tumbles clockwise,
2 times Low level spin,
3 times; High speed spin,
4 times Inlet valve for prewash,
5 times; Inlet valve for main wash,
6 times, Inlet valve for Hot water,
7 times: Inlet valve for softner,
8 times; inlet valve for bleach,
9 times; tumble counter-clockwise,
10 times; turns Heater on (if equipped)
11 times; circulation pump,
12 times; drain pump,
13 times; power off and unlocks the door
Good Luck!!!
May 03, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
TE error code
Note that there is am error in some guides. They say a maximum of 194 degrees (F), It should be 149 degrees. Re-check that inlet water temp is less than 149 degrees. Optimal and minumum temperature is 120 degrees.
A failing thermister is pretty rare.
Please report back with what has been found. Thanks.
Aug 21, 2008 | LG LDF6810ST Stainless Steel Built-in...
Trouble code LE
I believe that your error code is "IE". If so,its relates to water input problem Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You should replace it. Be aware you should disconnect the power cable from machine before doing it !!!! Good luck
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
LG LDF6810 Built-in Dishwasher Logo
482 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
