Dell Flat Panel Model: E133FPb, built Sept. 2004 BBB
Turns on for 1 sec. then the screen goes black. You turn it off and then on again, same thing...
span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; } span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; } span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
  • 293 Answers
SOURCE: my Dell Monitro goes black about 4 seconds after being turned on
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it.
Posted on Nov 13, 2008
  • 135 Answers
SOURCE: Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Posted on Feb 24, 2009
  • 5 Answers
SOURCE: Panasonic DMR-E85H
This is a hard drive failure and is expensive to fix, and not worthwhile in my opinion.  Mine packed in with a disc stuck in the disc drive. It was difficult to retrieve. If you have no disc trapped in the tray, I would suggest dismantling anyway and removing the hard drive if you have a load of unwatched content recorded. You can buy a cable to hook it up to a PC - Although I have not done this yet.
DMR-E85H - Rest In Peace.
Posted on Mar 18, 2009
  • 558 Answers
SOURCE: dell 17'' flat panel monitor power light is blinking
some transistors on the board have shorted they supply power to the inverter to run the lamps, they power is not cut off intermittently and the protection circuit has stopped the monitor. the fix is here
goo dluck if you want it fixed for you let me know
Posted on Mar 22, 2009
  • 19 Answers
SOURCE: Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Posted on May 16, 2009
My Philips 50PF7321D/37 TV picture turns blue after about 30 secs of being on and I cant seem to get it to stop. Also when I turn the TV on it has a black screen with sound for about 15 secs before it
Unplug both the set and a box or receiver if used with the set, remove from power for several minutes and replug all to see if a reboot will help or not.
Dec 09, 2012 | Philips 50PF7321D 50 in. Plasma HDTV
My monitor is a dell 2000 flat screen 20.1" turns
It is not so difficult to repare if you have scills to open the monitor and scills in un-soldering/soldering electronic components, than yes it is worth it, but if you go to a shop they have a tendency to sell you another monitor since the price they charge to repare the powersupply is about the same as a new monitor
Feb 18, 2011 | Dell UltraSharp 2000FP 20.1" Flat Panel...
I have an older desktop Dell computer and it turns on for a sec thenthe screen goes black you can still se it faintly. I was told it might be a capasitor but I opened it and checked the inverter and see no...
How did you check the inverter?
If you get a "very-dark" image, then the most-likely cause is a non-functioning inverter.
Buy a replacement (on eBay????) and install it.
Oct 04, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
I have a Dell SE198WFP Flat Panel Monitor, screen goes black?
The LCd panel may be damaged and will cause this problem.
Another thing is overheating of the GPU.
The LCD signal receiver can be goign on you.
The is also the possibility of a faulty inverter.
Only thing to do is service or replace. Test the unit on another computer, if you don't get the issue there then you know its a problem with the PC.
Jun 03, 2010 | Dell SE198WFP LCD Monitor
I would really hope someone would its a dell LCD issue :(
you can contact dell and ask or google it to see if anyone else has experienced your problem.
Jan 04, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Corporate Computer
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
