Question about HP Compaq nx6310 Notebook
Inverter need to know how to change the inverter
    Sergeant:
    Champion:
  • 274 Answers
The procedure differs a little from each make/model. But mainly your removing the outer bezel around the screen with screws, snaps, and pressure points. Some inverter are behind the panel and are bigger, but the connector looks the same.
Warning: Handle the inverter with care. It still has a HIGH electrical charge, even when removed.
Here is a link to a tutorial...
http://www.laptoprepair101.com/laptop/category/replacing-screen-inverter/
Posted on Nov 20, 2008
  • HP Master
  • 4,806 Answers
The inverter is located unerneath the monitor ( lid ), behind the bezel ( plastic cover that surrounds the screen ) unscrew the front cover and you can't miss the inverter its an elongated circuit board, just disconnect it and replace. You may have to take the lid off to get to the inverted depending on the bezel type
hope this helps
regards
How to change the fuses on ring 500w power inverter
Ben, Re POST make, model #, and complete question so we can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 26, 2016 | Inverter Electronics - Others
How to change blown fuses
Ben, Power Inverters of different make and style use different fuses, I will post links for you to check out.
Replacing Fuses Power Inverter
Homemade Circuit Projects How an Inverter Functions How to Repair...
Battery Sales Inverter Frequently Asked Questions FAQ
POWER JACK GRID TIE INVERTER REPAIR THE MOSFET MISHAP
Feb 26, 2016 | Electronics - Others
What do the pinout signals mean for the inverter 6632L-0536A?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 25, 2015 | LG 55LH40 55 in. LCD HDTV
Need to find the inverter on my dell studio laptop
It is at the base of the screen, right below the LCD. Here is a diagram:
http://blog.parts-people.com/2011/04/04/dell-studio-1535-1536-1537-lcd-inverter-removal-and-installation/
Let me know if you need further assistance. Changing the inverter isn't very difficult.
Good luck!!
EJ Kudelka
May 25, 2011 | Dell Studio 17 Laptop
I have a Aims Inverter PWRINV5000W with all the lights on but no output at plugs.
Hi!!
There is a fuse or thermal device for the AC outlet(s) protection, is either next to the outlet or same place but inside the unit. The cover need to be removed to change/reset it.
Let me know if you found it. Good Luck!!
Dec 08, 2010 | Inverter Aims Pure Sine Wave Power...
VERTICAL HOLD CONDENSED TO SINGLE LINE IN MIDDLE OF SCREEN.USED TO ROCK IT TO GET FULL SCREEN,BUT THAT NO LONGER WORKS. I KNOW THE CHIP IS LOOSE BUT I DONT KNOW WHERE IT IS SO I CAN REPLACE IT.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP IN SOLVING THE PROBLEM...
Nov 02, 2010 | Televison & Video
I have a protron pltv-4250 with vertical lines only on the right side. I dont know what to look for and what to repair? i am very qualified to do this i just need another point of view
Hope this in solving the problem.....
Oct 11, 2010 | Televison & Video
I have a permanent dark/black 4.5" wide vertical line on left side of plasma TV. It seems as if it is 4:3 display mode on left side only. Any help would greatly be appreciated. I have no problem changing...
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER .
BUT IF OTHERWISE CHECK
x driver cables 10 ohm resistors have loose connections
Hope this will help...
Jun 14, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
I changed the inverted in my toshiba satellite
Sounds like the screen itself is bad or possibly the plug is bad to the inverter or motherboard.The videocard sounds like its ok.
Oct 03, 2009 | Toshiba Satellite M45-S331 Notebook
HP Compaq nx6310 Notebook Logo
154 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
