Question about Dyna-Glo D-E36 Infra-Red Wall Mounted Panel Heater
Shuts off when switched to low and smells when running.
Have a DYNA-GLO model RMC-50LPT propane wall mounted heater has a heat setting from 1 to 7 will run on high settings but when switching to settings 1 to 3 it will shut itself off . It running on a 200-250 lb outside stationed propane tank and its at 75% full.Also its sort of hard to get the piliot to light but i have always managed to get it to. When its running on eany other setting other than 1 threw 3 it has a smell to it sort of like when you shut a kerosene heater off and they develop that fowl smell?The heater is mounted in our garage,although the garage is very clean im wondering if the unit is dirty down in the orfice.Its not a brick infared heater it actually has the blue flames that raise when the setting is turned up . Thanks Shawn
  • Dyna-Glo Master
  • 2,894 Answers
Clean the burner and the orifice you can use a air line or blow off a vacum cleaner
Posted on Feb 07, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I have a Dyna-Glo heater, model #RMC-FA50A, heater will not get hot and there is a odar and eye burning smell after running a short time.
When this type of problem happens, you most likely need to take apart your heater and clean it well. If it still doesn't work after that, blow it out with an air compressor. If then it still isn't working, I suggest you sell that heater and buy a new one.
Dec 17, 2011 | Dyna-Glo Heating & Cooling
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
Dec 17, 2010 | Heating & Cooling
I have a Dyna-Glo RMC-50LPT propane heater that is about 5 years old and I can't get rid of the yellow flames when it operates. I have tried: - removing the heater and blowing everything out with a...
Dennis easy fix what is your out going gas you will need a manometer to verify it accurately or adjust your gas valve til your blue flames are gone. Let me know what you find!
Dec 16, 2010 | Heating & Cooling
Dyna-Glo model RMC-8000PGH will not stay lit
Your pilot safety is full of dust. Flush it out with shop air or rust buster. Retry
BONUS INFO
Dec 17, 2009 | Dyna-Glo RMC-8001SS Heater
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
How long will one pound propane tank last
The 16.4 oz propane bottle contains 1.02 pounds of propane.
1.02 lbs propane equals 16.320 oz
16.320 oz equals 22.032 BTU’s.
The RMC-8001SS has two settings, maximum and minimum
The Max setting is rated at 8,000 BTU hour.
22.032 divided by 8,000 equals 2.754 or 2-3/4 hours
The Min setting is rated at 4,500 BTU hour.
22.032 divided by 4,500 equals 4.896 or 4.8 hours
One 16.4 ounce bottle will burn 22.032 BTU’s @8,000 BTU’s per hour for a period of approximately 2-3/4 hours and @ 4,500 BTU’s per hour for a period of approximately 4.8 hours.
Jan 18, 2009 | Dyna-Glo RMC-8001SS Heater
Dyna-Glo D-E36 Infra-Red Wall Mounted Panel Heater Logo
487 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
