Question about GE Ovens
GE Wall Oven is iratic
16-year old unit has given good service until recently. Now it works fine sometimes, but not others. Specifically, one cannot trust the temperature. Yesterday it repeatedly shut down with a "PF" signal. The muffins were ruined. Interior light still works so it has power. Model # J KP14WOP1WG S/N MF638835Q. Thank you.
catriver
  • 878 Answers
SOURCE: F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Posted on Mar 04, 2007
Master_Tech
  • 770 Answers
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
Please post the Model # from the units tag and i will see what I can do for you
Posted on Jan 26, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
SOURCE: Kleenmaid Scala wall oven and grill
manual available at www.kleenmaid.com/care
Posted on Feb 15, 2009
localwonder
  • 6784 Answers
SOURCE: My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
Posted on May 22, 2009
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Jan 26, 2008 | Ovens
We have a double wall oven which is 16 years old. The top oven doesn't heat above 150 and the bottom oven is overheating...the oven said 375 and an oven temperature gauge said 450. Is this fixable or do I...
I have the same issue. Only answer I found was the elements may be burned out. The bottom oven is separate (knobs).Go to GE site and see how to adjust the thermostat (behind a knob).
Nov 01, 2009 | GE JKP27 Electric Double Oven
I have a brand two month old GE 27" wall oven. It takes a very long time to pre-heat, sometimes up to 30 minutes for 350. Any ideas? Is this normal?
check your power connections, do you get 240 volts between red and black, 120v red/black to white? at outlet and in unit
Jul 05, 2009 | GE JKP30BMBB 27" Built-in Single Electric...
All four burners click at the same time; Sometimes will not light
hey mate i have had this problem with my oven, they get moisture in them. Turn it off at the power point for a few hours or before you go to bed and turn it back on the next morning and it should be fine. that should get the moisture out. hope this helps. Keeno in OZ
Mar 19, 2009 | GE Ovens
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
Ge wall oven old!
here is a link that might help out.
click here
Choose your location from the link. A local service number is displayed. Get a repairman to visit the place, and then describe the problem; in this case the broken hinge. This should certainly work out.good luck. Please add your comments and also do tell me if you are located outside US.
Jan 09, 2009 | GE 24" Built-in Single Electric Wall Oven...
Dec 27, 2008 | GE JKS05 Electric Single Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
No power
First thing to do is pull the oven and check if there is 240 volts going to the oven. The display works off 1 of the 120 volt legs of the 240. If you have the 240 volts, then your issue is with either the display or relay board.
Jan 06, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
59 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
